Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Apr 2006
    hello guys, need some help about my concern.
    everytime ino-on ko kasi ang aircon ng tsikot, may squeeking sound. pag inoff ko nawawala. im not sure if alternator or compressor yun. which is which kaya?
    also, could this mean sira na yun or maluwag lang na pwede iadjust ang belt?
    TIA
    Quote Originally Posted by jundogg View Post
    TIA
    compressor bearing yan bro. try mo muna sprayan ng WD-40.
    Sep 2004
    Yup, malamang compressor bearing yan. Pero its an indication na its on its early dying stages. Kung pwedeng palitan, habang maaga, papalitan mo na. Some compressors kasi, like Calsonic, disposable.
    Apr 2006
    naku ganun ba? gastos nanaman.
    di ba madadaan sa higpit lang ng belt?
    mga magkanu ba (average) ang replacement at anu ok na brand?
    Apr 2006
    hi again. i just checked my car at nakita ko na humihinto ang compressor at certain instances that causes the squeak!
    my suspicions:
    1. maluwag ang belt.
    2. bearing needs lubrication (as per you guys)
    3. sira na compressor...at wag naman sana. =(
    yoko iconclude un #3. huhuh
    pwede kaya masolve lang un ng either #1 or #2?
    Apr 2006
    by the way, masama ba yung i-on ko padin ang aircon while driving kahit na nawawala naman yung sound pag mabilis na ang takbo ko? tumutunog nalang uli pag gapang nalang ang andar.
    thanks for the help
    my suspicions:
    malabo yung belt bro. its either #2 or #3. i also experienced this last week nung bumabagyo and bumaha. medyo tumunog yung compressor bearing ko dahil nabasa siguro.
    what i just did is to have it sprayed with WD-40 (onti lang, hwag lulunurin), while it is spinning. ayun, nawala na.
    Sep 2004
    Better siguro kung belt dressing, kasi masyadong madulas ang WD-40. But that is only a temporary fix.
    I drove with that squeak for 1 year siguro on my Sentra. Intermittent lang, minsan meron, minsan wala, so akala ko before either maluwag yung belt or basa. Little did I know na pabigay na pala yung compressor bearing. Buti na lang hindi nag-stuck up, otherwise, tinirik daw ako. Ended up buying a surplus compressor.
    Hopefully, yung sayo, pwede pang palitan.
    Apr 2006
    thanks for the input guys.
    potek to. mapapagastos pa yata ng wala sa oras.
    my ride is a nissan california.
    Aug 2005
    TIA
    pagtumunog basain mo ung belt para malaman mo muna kung saan galing pag dinawala malamang bearing na nga or pwede rin ung clutch pulley nya manipis na kaya medyo tumatama na ung rivets. clutch n pulley dami ng surplus nyan mura lang, better paayos mo na pagnagstock up yan dami sisirain lalaki gastos mo. kung brandnew na bearing below 1T lang din + freon n labor
    Apr 2006
    kita ko na kung anu ang maingay. not much sa compressor kundi dun sa may bilog between compressor at makina. yung parang pulley. nilagyan ko ng contact cleaner/lubricant spray. ayun mejo nawala na unlike dati.
    mejo kinalawang na kasi.nababasa tuwing tag-ulan.
    hope what i did might do the trick. =)
    papalitan mo na ang bearing nyang idler pulley ... kundi babalik din ang tunog nya, worn out na kasi ... mura lang naman ang bearing nyan
    Apr 2006
    Quote Originally Posted by kinyo View Post
    mga magkano po yun sir? at iba-ba ba yun dipende sa make and model ng car?
    no idea ngayon, pero noong 2003 nagpalit ako para civic ko dati, less than P200 lang ... mura lang, pero antagal ng buhay
    yup, iba-iba ang part number nyan depende kung anong oto, pero marami nyan sa mga auto parts stores
    dalhin mo na sa suki mong mekaniko, ituro mo lang yung bearing na kailangan palitan ... wala pa siguro P500 na gastos, pati labor na yun
    OT: nahuli mo na ba yung magnanakaw ng pagkain mo?
  15. #15
    kung squeaking, baka aircon tensioner bearing needs replacement....otherwise, compressor bearing na yan..
    para isang gawa na, sabay mo na sa linis ng a/c mo, para di sayang ang freon..
    Apr 2006
    Quote Originally Posted by Galactus View Post
    sorry i'm not much into cars, but kapag nasiraan ka ng compressor ititirik ka? i mean if it's stuck, can't you just turn the aircon off and drive to the repair shop? how come affected ang buong car if it's just the compressor? thanks
    Sep 2004
    Pag na-stuck kasi ang bearing ng compressor, hindi na ito iikot, kaya chances are either mapuputol ang aircon belt, which is also connected to the water pump ata (or power steering pump, not too sure). You can't drive with a busted water pump, otherwise, mag-ooverheat ka agad. At least that's what the mechanic told me.
    Apr 2006
    ahh thanks sir galactus. medyo nagiingay rin kasi yung sa akin. might as well drive without aircon muna until i can bring it to mang mario's this saturday.
    Apr 2006
    thanks sa estimate. ill consider that in my elimination process.
    about the OT (hehe): di pa nga eh. gagawa palang din ako ng pain.
    Nov 2006
    makiki-sakay din po ako. . .
    yung compressor ko ang tunog parang pusa "lumalandi"
    yung parang tunog sirena ng bumbero.
    compressor bearing po kaya ang may problema dito?
squeeking sound when aircon is on
