Results 1 to 10 of 17
- Aug 2006
- 98
November 7th, 2013 11:30 PM #1Mga sir, just a few questions lang po:
- Paano ba malalaman if working pa or defective na ang thermostat?
- Ano po ba itsura nun and san banda sa engine bay makikita?
- Ano recommended coolant but not too pricey for honda 92...yung National na brand po ba ay pwede na? Yan din kasi ang gamit ko sa isang auto namin.
TIA
November 8th, 2013 09:47 AM #3
kakapalit ko lang ng coolant sensor and thermostat kahapon.
symptoms that i've encountered:
a) ang lakas magbawas ng coolant sa radiator, pero hindi nagagalaw ang coolant sa reservoir.
b) hard starting. usually, it takes me around 4 tries to start the engine, specially during mornings.
c) higher than usual FC. my normal FC is around 12 kpl... bumaba ng 9 kpl.
d) rough engine.
e) overheat
the thermostat controls that flow of coolant papasok ng engine. pag mainit na, bubukas ang thermostat allowing coolant to flow in... pag lumamig, sarado yung thermostat and it allows the engine to warm to optimal operating temperature.
on the coolant, i use prestone pre-mixed.
- Aug 2006
- 98
November 8th, 2013 09:56 AM #4
- Aug 2006
- 98
November 8th, 2013 09:58 AM #5
November 8th, 2013 10:02 AM #6
think so.
since engine is always running cool, you need extra fuel to run properly.
yung hard starting, malamang dun yun sa coolant sensor... pero someone related to the thermostat, since maski tama ang binibigay na data ni coolant sensor, but sira naman yung thermostat mo, hindi sya bubuka and sasara ng tama.
meron pa palang isang symptom..... nangangamoy ang coolant after shutting down the engine. it means, parating bukas ang thermostat.
- Aug 2006
- 98
November 8th, 2013 10:26 AM #7
November 8th, 2013 11:13 AM #8
November 8th, 2013 02:10 PM #9
- Aug 2006
- 98
November 8th, 2013 09:25 PM #10
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
