Results 1 to 20 of 32
    My radiator is cracked and neremedyohan ko lang. I notcied na nababawasan yung water ko, that means my colling sytem is not efficient. I was wondering where I can a replacement radiator for a Civie esi a/t?
    Help me out
    Dec 2002
    Is the crack on the top plastic cover of radiator? If so, go to a Denso shop. They can replace just the top portion and check the rest of the radiator.
    Denso shops in Banawe and across Meralco bldg, inside auto camp.
    problem is... I have the crack on top and a leak sa body of the radiator. It won't be long and my radiator will die
    AFAIK, aluminum ang radiator ng ganyan and can't be repaired...
    you can try buying a OEM radiator but it'll be pricey (around 8K). you can also try scouting for a surplus radiator (around 2K).
    okay lang ang surplus ng Civic... they're kinda strong anyway.
    Evercool makes replacement radiators for most popular vehicles.
    DENSO has radiator repair facilities also.
    scout for a surplus...dami naman sariwa sa banawe.
    Why not get in touch with Auto_Xer? Maybe he can hook you up with radiators -- customized pa kung gusto mo...
    Sep 2004
    oks naman japan replacement radiators..changed mine 2 years ago... honda makati even offered me this part instead of the original. price around P8k
    nmtin: same car pla tayo and model...hehehhe...same sira also..hehehe
    av8or5 ano yung naging replacement rad mo??? aluminum type pa rin ba or nickel type na???
    May 2004
    sabay lang pala tayo nagpalit ng radiator av8or5. nakuha ko ng 2thou plus yata (kasi medyo sariwa) sa surplusan near us.
    Sep 2004
    jim: not so sure bro...
    niwde11: hehehehhe.. same car tayo..same problem pa...hehehhe... nagpalit din ako power steering pump...pero.surplus din sa banawe..oks din
    dapat sama sama na rin tayo nagpalit :D para mas mura
    Dec 2002
    pasingit po,
    meron din kaya replacement radiator for the camry 97 ?
    Feb 2003
    get an evercool 2-rows radiator, mga 3k lang ang brand new
    Dec 2002
    sir wrecker,
    May transmission cooler sa ilalim ng radiator ko, automatic transmission kasi ang camry. Does evercool have this ? And where can I buy the ever cool? Maraming salamt po : )
    Oct 2004
    nmtin,
    Un radiator mo b eh un aluminum type na plastic un upper part? If that's the case d na maaayos yan... suggest ko kuha k nung "tanso" type.. since repairable un ganito klaseng radiator...
    Quote Originally Posted by KALAMPAG
    nmtin,
    nagtanong ako sa Denso pwede daw maayos yun basta made by denso yung OEM radiator na kinabit ng manufacturer. around 1.8k yung plastic top and 500 for labor and gasket.
    Problem with my Gen1 CR-V di gawa ng denso yung radiator meron silang replacement top for Gen2 CR-V lang and Civics ( di ko sure kung ano year model)
    Might as well replace my radiator na lang with everkool. makabisita nga sa masangkay sa binondo. I saw a shop there selling everkool radiators malapit sa warren automotive.
    Jan 2004
    had mine converted to "tanso" yun lang upper part, sabi nila mas ok daw yun kasi "tanso" as kalampag said can be repaired and mas matibay daw yun.
    Nov 2004
    the auto aircon shop I go to repairs, by welding, aluminum evaporators. These are kind of like radiators. I guess you can try your local backyard auto aircon shop if they can repair your radiator.
    fair warning though, I haven't used repaired radiators so I have no personal experience if this type of repair will last. My aircon though is working fine, repaired evaporator and all. welding aluminum is lot tougher than welding copper or steel and few welders are skilled in this trade.
replacement Radiator
