Radiators:
Brass&Copper VS. Plastic&Aluminum
Which do you think is a better product? why?
Radiators:
Para sa akin Mas OK ang brass & copper. Dahil doon sa company namin. may driver kami naputukan ng radiator. Plastic yong cover.nasabugan sa mukha. Gusto niyang buhusan ng tubig yong radiator para lumamig kasi nagoverheat. Unang buhos palang niya biglang umigkas yong plastic cover. Kaya sapol sa mukha. Yong plastic at aluminum hindi na siya puede marepair kapag may leaks na. Kapag pinarepair alanganin na. hindi 100% na hindi ka ititirik.
A radiator top is a release valve for excess heat and pressure. If the radiator doesn't give way, it's possible the head gasket could. And that'd be a more expensive problem than a cracked radiator.
Your choice, though.
Guys,
i have 16 years experience sa design and manufacturing of radiators, at ito yung pwede ko ma share sa inyo:
1. By weight basis mas magaan ang radiator na gawa sa plastic & aluminum compared to brass-copper (doble ang bigat).
2. In terms of thermal conductivity ng materials:
a) Aluminum : 220 W/m-c
Tubes : Aluminum
Fins : Aluminum
b) Copper : 380 W/m-c
Tubes : Brass coated with solder
Fins : Copper
* Mas mataas ang thermal conductivity ng copper, but this will have
minimal increase in the cooling performance.
3. Plastic tank is repairable but short life, mas maganda ang brass tank mas madali ma repair.
>>> Plastic-aluminum radiator is best suited in low ambient temp.
>>> Brass-Copper radiator is best suited in tropical countries like the
Philippines
In addition dito sa atin we are only making conventional brass tubes coated with solder while the aluminum tubes they come with different enhancements such as dimpled tubes, internal turbulators, etc.
ako nag parepalce ako yesterday ng evercool Radiator.. All copper.... for my Rav4 Gen2...
vitara bro.,yung may ist owner ang nag drive.faulty thermostat plus sira yung temperature gauge kaya hinde nya alam nag overheat na pala.the oem rad eventually crack after ayear of that incident(no overheating),we`re using now evercool radiator mas cooler siya compared sa oem radiator.
