Results 1 to 7 of 7
Threaded View
BANNED BANNED BANNED
- Jul 2010
- 44
July 13th, 2012 01:25 AM #1Mga bro question lang. I'm using a replacement mechanical aircon thermostat as the original broke already. The car is a 98' ae111 gli.
The mechanical thermostat has a knob which was set at parang 2/10 of the way lang. kelang yung lamig para sakin lalo pag tanghali di kalamigan yung buga ng aircon.
I tried adjusting to full right yung knob and i got a relatively cooler output.
Problem ko is panu ko malalaman if nag auautomatic pa yung compressor? how do you know na nag aautomatic shut off ung compressor when i reach a certain temperature? yung stock ata kasi na thermostat is not mechanical. parang closed pod box sya na walang control and programmed to switch off the compressor when it hits the programmed temperature.
Baka kasi maging stressed masyado yung compressor at mag build up ng yelo sa system.
thanks mga bro!
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
