Results 11 to 20 of 22
    Sir naka vti ako, ganyan din sakit. Pero ung akon nakita ko sa hoses.
    Ang ginawa ko nahlagay ako ng coolant na matapang ung kulay, say red, green or etc. Then testing, nakita ko na ung leak eh paunti unti sa may hose connection dahil sa tuyong kulay ng coolant.
    Try mo sir baka makatulong.
    Posted via Tsikot Mobile App
    Apr 2012
    Quote Originally Posted by dongsky07 View Post
    sir fill up the reservoir until full mark lang, wag hanggang tip. Issue ko to dati, i fill it in hanggang mag overflow and yet daily laging bawas sya til someone told me not to overfill it. naging stable sya sa full level since then.
    Hi sir dongsky07, thanks sa suggestion po. I tried this one pero ganun pa rin eh. Napansin ko may tulo na sa umaga sa garahe namin pero not that much.
    Quote Originally Posted by brainmafia_310 View Post
    Thanks din po sir sa suggestion, itatry ko po ito next time kasi nagkaproblem naman yung sa AC ko kaya AC nlng muna uunahin ko.
    ^^ alright kung taga cavite ka meron mahusay at mutang gumagawa ng ac sa queensrow. Mas mura pa piyesa niya sa evangelista at banawe. Di ko nga alam kung san galing eh
    Apr 2012
    naku bulacan pa po ako, ang layo ng cavite hahaha!
    I think it's in the hoses. The clamps may be loose. Check this article out - The Causes of a Leaking Radiator Hose ? And how to fix one - Roberts AIPMC Blog. Hope it helps. May leaks din ba when your car is idle or not running at all?
    Sep 2014
    Boss Brainmafia, san sa QR? Springville lang kasi ako
    Apr 2010
    I have a Federal Mogul 0.9 cap, new hoses, napa overhaul na rin ang radiator some time ago. A small cup or less ang water loss sa akin every week - di ko alam kung normal ito, wala namang overheating. On 50/50 coolant:water mix.
    In some cars, the source of the leak is the water pump. If this component is hidden from view, detecting the leak is difficult.
    Aug 2012
    Quote Originally Posted by ParticleX View Post
    ang normal is walang mababawas na coolant. pero kung nagbabawas ng 1 small cup per week, malakas na leak yan. kung 1 small cup per year or kahit every 6 months, tolerable pa siguro.
    kahit may leak sa system, walang overheating na mangyayari basta di maubusan ng coolant ang radiator mo. kaya check coolant level always and top up when needed.
    Apr 2010
    Quote Originally Posted by red_one View Post
    Estimate lang naman yung one small cup per week, minsan two weeks na lumilipas parang wala pang nabawas. Dunno kung ano ang history ng water pump neto. '92 model pala baka dahil sa tanda na rin.
    Ganun rin ang rate ng water loss ng Hilux namen kasi sa probinsya eh
Radiator and Reservoir still losing water after cleaning
