Results 1 to 9 of 9
- Sep 2010
- 131
October 31st, 2010 06:01 PM #1I can't drain my radiator... i think it's stuck... i can't turn the plug... will this damage the radiator if i put alot of pressure ending up with broken radiator or plug? What could have caused it to stuck?
- Sep 2010
- 131
- Nov 2009
- 456
November 1st, 2010 06:41 PM #4If you force it, you highly risk cracking the drain plug which is usually made out of plastic (which should be brittle by now). If this happens, you will be forced to buy a replacement which should readily be available at the casa.
- Sep 2010
- 181
November 1st, 2010 06:49 PM #5
November 2nd, 2010 03:26 PM #7
Buy the replacement plug. Use pliers or any suitable tool to remove the old plug. Contact should be made as near to the thread as possible. The idea here is to remove the old plug in one piece.
If you break off the head of the plug, you have no choice but to drill out and extract the remaining plug.
- Aug 2008
- 65
November 2nd, 2010 05:18 PM #8
- Sep 2010
- 131
November 2nd, 2010 09:46 PM #9
Traffic!
