Results 1 to 10 of 10
- Nov 2002
- 51
January 10th, 2004 05:34 PM #1I saw at Ace hardware a product named Whiz Radiator Stop Leak. It claims to stop all leaks in both radiators and engineblocks whether its steel, aluminum or copper. Ok ba ito?
The radiator of our 10-year old Feroza still loses water every now and then after a radiator repair, cap replacement and check-up. Wala naman daw butas sa radiator or sa hoses. Do you think these stop-leak products are effective?
Thanks. :confused:Last edited by Mike2; January 10th, 2004 at 05:36 PM.
January 10th, 2004 05:54 PM #2
Nope. It might just clog your radiator core.
Baka leaky na ang cylinder head gasket ng Feroza kaya nagcoconsume ng water.
- 3,754
January 10th, 2004 07:37 PM #3kung walang butas ang radiator bakit ka gagamit nyan... baka lay leak na din water pump...kaya nawawa tubig.. it happened to my VAN...pinalinis ko Radiator Ok naman dinala ko sa casa nakita leaking water pump na talaga
January 10th, 2004 07:53 PM #4
pang emergency lang yan, remedy lang until you can change your leaking radiator. we do have stock of that here on the rig just in case our smaller engines (as in 350-700hp crane and emergency generator) develop a leak. effective but to a limited extent (dapat maliit lang ang leak). pag malaki na leak sa radiator di na kaya nyan. palit radiator core na din. it only works on copper radiator cores nga pala. sa engine block and cylinder head useless yan.
January 12th, 2004 12:53 PM #5
don't use it. magsisisi ka lang. lalong dudumi ang radiator mo.
add ko lang
try to replace first d radiator cap. buy a branded radiator cap (denso) at wag ung chipipay. Wala kwenta ung rubber seal ng chipipay na brand.
- Feb 2004
- 24
February 28th, 2004 08:00 PM #6Originally posted by Mike2
Thanks. :confused:
- Mar 2005
- 10
April 13th, 2005 11:29 AM #7Whiz has two products in the market for radiator leaks one is powder based the Quik Seal and another is liquid based the Metal Seal. Both are effective for small leaks. Wherever radiator fluid passes through, the product will reach it. For those who are wary about it clogging, they can use the liquid version.
- Jul 2009
- 54
June 19th, 2010 11:02 PM #9ask ko lang if may nakagamit na sa inyo ng alumaseal radiator stop leak? may leak yung rear plate ng cylinder block ko eh in between the engine block and transmission... option ko is to drop down the transmission to have the plate replaced, or use this stop leak product? any insights? magkakaproblem ba transmission ko non pag binaba, automatic yung akin eh?
June 23rd, 2010 07:28 AM #10
Parang stop gap solutions lang mga ito. Hindi pang matagalan. kung nawawalan ka ng tubig (because of a radiator leak, head gasket leak, busted head) dapat pa ayos mo na or palitan as soon as possible. gastos
My Ford SYNC just updated itself. Anyone here knows what was updated?
2023 Ford Everest Owners Thread
