Results 261 to 270 of 287
December 6th, 2018 12:48 PM #261
ADR yung three letter word na radiator siguro. Evercool is good too. Used it on my 96 City before. Disadvantage is tanso siya so mas mabigat sa stock na plastic/aluminum.
Same sentiments. Sa dami na ng brands ngayon mas gugustuhin ko pa na brand new. Siguro kapag sobrang nagtitipid tsaka lang tsaka ako magpaparepair.
- Nov 2009
- 3,509
December 6th, 2018 12:54 PM #262Evercool is local OEM for mitsu kaya may kamahalan. The taiwans are cheap and good quality, i just replaced one for hyundai and throw away the old nabulok dahil hindi nagpalit ng coolant.
Kaya yun DIY minsna nagiging Destroy it Yourself..Hehe.
Kaka kalikot yung pyesa na nabuksan at nagalaw dun nanganganak problema.
Kaya minsan need talaga research gather experienced method to find the root cause than the elimination method of troubleshooting.
Eto co-worker ko nag PMI DIY ng brake drum cleaning na hindi binacking ang adjuster, ayon pinwersa using eject slot na tornilyo kaya misaligned need nya palitan brake shoes.
December 6th, 2018 12:57 PM #263
Naging Destroy it yourself. Hahaha
Its all part of the learning process....
December 6th, 2018 01:35 PM #264
ill checkout my work later, kung ok ba or hindi yun alum clips
if ADR nga yun sa toyorama, ok na kaya yung ADR bro?
sa weekend mag semi long drive ako, then check if may leak yun DIY ko. ngayon kasi naka distilled water muna, kaso di madetect sa distilled water dahil nag evaporate agad, nun pinalitan ko nalang ng coolant, tsaka ko nakita yun mga tulo from a very small leak.
- Jun 2005
- 3,774
December 6th, 2018 02:28 PM #265
December 6th, 2018 02:31 PM #266
December 6th, 2018 02:43 PM #267
^ i'm not sure but i think taiwanese made ang adr bro.
i bought an evercool rad for my ek several years back to replace the original oem rad it came with and it performed very well. the price is worth the quality of the product.
btw, iyong adr ba aluminum na? kasi iyong 2 row evercool na nabili ko dati gawa pa sa brass.Last edited by baludoy; December 6th, 2018 at 02:50 PM.
December 6th, 2018 03:52 PM #268
December 6th, 2018 04:03 PM #269
December 6th, 2018 04:26 PM #270
I might be wrong about the origin of ADR. But im sure evercool is locally made.
Edsa is about 24kms long. So, 15b / 24 is approx 625m per km?
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
