Results 51 to 60 of 287
June 6th, 2017 02:31 PM #51
June 6th, 2017 04:31 PM #52
I totally disagree with this as far as heat resistance is concerned
But then again brackish water has a way to weaken metal structure with corrosion
Ill still put my money on a metal cap (corroded or not) rather than a plastic one due to the function of a radiator, absorb and dissipate heat generated by the engine combustion process
Sent from my GT-P3110 using Tsikot Forums mobile appLast edited by kisshmet; June 6th, 2017 at 05:52 PM.
- Jun 2017
- 6
June 16th, 2017 06:25 PM #53Mga bossing pa-help naman po. Newbie here in tsikot. Yung 2009 hyundai tucson crdi ko nakita kong may bahid ng langis yung hose coming from compressor going sa bakal na connecting sa expansion valve. Sabi nila may leak pero malamig parin po ang buga ng A/C ko kahit 1 week ko nang nakita yung suspected leak. may slight hissing sound din sa loob pag nasa #2 or 3 sya. Ano kaya problem ng aircon ko. worried lang ako baka masira compressor ko Is this really a leak? Thanks Y'all!!!
June 16th, 2017 06:31 PM #54
pictures.. use the tsikot android app. its easier to attach pics
you're flooding pala... youll be banned soon.
- Mar 2014
- 901
September 7th, 2017 11:59 PM #56
- Jun 2017
- 5
September 13th, 2017 08:09 PM #57(Chevrolet Venture LS 2003, V6 3.0li Gas)
Overheating Chevy Venture...
never had a problem regarding this until about years ago.
1) the Radiator, Radiator Cap, Water Pump, Thermostat are now all new. Recently flushed and coolant (Shell Reco-cool) replaced
2) both Cooling Fans (driver side and passenger side) are now all new, including the Underhood Fuse/Relay Junction Box who's terminals burnt out (the new one burned also, apparently a design flaw...resolved by soldering the failed wire directly on the pin)
3) A/C Compressor (Delphi) was replaced 2 years ago and should be still be relatively "new"
These worked for a while until recently when it began overheating again!
Wizzard recommended getting the ECU/PCM checked by "someone in Banawe" coz they find nothing wrong with the wiring. Apparently the computer is not closing the ground on the relay.
They temporarily setup up a toggle-switch that directly hooks up the power from the battery to the driver-side aux fan so I may drive the van and not need towing. It works but of course the "Check Engine" warning light switched on.
Has anyone encountered a similar problem before???
- Dec 2016
- 16
- Mar 2010
- 4
September 22nd, 2017 05:02 PM #59
- Jul 2017
- 14
September 22nd, 2017 08:57 PM #60Makiki ride na po dito sa thread, nag pa overhaul po ako last July ng rad ko tapos napansin ko na nabawasan yung coolant ko sa reservoir check ko po meron leak sa rad ko. Ayaw ko na po ibalik don sa pinag paoverhaulan ko para ipabaklas pa ulit. Balak ko na po na palitan na lang ng bnew. Di naman po ako lumalayo layo dito dito lang ginagamit yung auto. May masasuggest or refer po ba kayo saan ako pwede makapag canvass ng mga radiators and thermostat? Toyota BB po ride ko. Salamat po.
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
