Results 31 to 40 of 287
- Mar 2014
- 901
April 5th, 2017 01:09 AM #31Ang symptoms pala ng Toyota Avanza nagbabawas ng coolant, kapag medyo barado na ang radiator neto, which need to be overhauled.
Sent from my 5015E using Tapatalk
- 54,205
April 5th, 2017 08:12 AM #32
BANNED BANNED BANNED
- Jun 2007
- 122
- Mar 2014
- 901
April 5th, 2017 12:24 PM #34Not on my experience with our ride. I encounter overheating that is already near red mark but never runs out of coolant in a radiator even in its reservoir tank. I also end overhauling the radiator when parts like thermostat valve and switch was replaced. The overheating problem diminished when the radiator was overhauled.
Sent from my Up Snap using Tapatalk
- Jun 2007
- 122
April 5th, 2017 11:21 PM #35
- 54,205
April 6th, 2017 01:30 AM #36
- Sep 2006
- 47
April 13th, 2017 04:26 PM #37How much is the typical range for radiator overall?
- 54,205
April 13th, 2017 05:36 PM #38some repairers do not repair plastic-topped radiators. "throw-away" radiators daw.
others replace (daw) the plastic tubs with brass tubs. don't know if this is true, or if the repair lasts.
i remember an overhaul quotation of 1800 bucks, but that was years ago.
surplus? we have no guarantee... that surplus radiator might just turn out to be in worse condition than yours.
surplus radiators have probably been languishing, dry, in the shop, for some time.
the corrosion-preventive properties of radiator coolant, have not been enforced on them for some time.
once installed in your car, they may just "leak like a ligadera".
brand new, to be sure. 5K or so.
errr... what's your car and radiator, po?Last edited by dr. d; April 13th, 2017 at 05:45 PM.
April 13th, 2017 06:33 PM #39
Had the plastic tub replaced with metal on my truck. Still ok until now, around 5 years later. Best thing to do would be to use premixed coolant to make sure corrosion doesn't start. I don't know why, but even with our best effort to get the right ratio of coolant concentrate to water, rust starts to appear a few months after.
- Mar 2013
- 220
April 13th, 2017 07:22 PM #40Kung around 80-100k ang mileage mo at working ang both fan, time to overhaul radiator at palit thermostat na din( bka naka stock half open eh). Plastic radiator O/H 5-600 petot (ikaw ang magkalas) kung mayhairline crack better buy replacement 3,500 last year pag auto.
Check mo lang sir rev engine 2.5k to 3k with out radiator cap pagdahan lumalabas ang tubig mo ah same tayo ng problem Replace head gasket kna din.
It is repairable. But as oj88 mentioned, it is messy (when repaired) and best used as a last resort.
Liquid tire sealant
