hi mga sirs,
yesterday i had the radiator of my mitsubishi eclipse 99, 4g63engine OVERHAULED, i think hindi yata na-flush (based on a thread i just read here) let me describe what happened, first tinanggal yung radiator, nilinis siya via water pressured hose both from outside and within, then tinusok-tusok yung mga holes or pipes para matanggal yung residue, then it was tested for leaks, wala naman. after that kinabit na po ulit yung radiator, i had neither extra coolant nor money to buy coolant at the time so TUBIG lang nilagay namin. NGAYON eto po nangyari, i started the engine, we deliberately left the RADIATOR CAP OFF para makita kung umiikot yung coolant etc.
then ang ginagawa ko po, based on past experience ni-rev ko yung makina to see kung bumubulwak. apparently ang nangyari, NAG BUBBLE and FROTH (like cream) yung opening ng radiator. I began to worry, so i checked the TEMP, ok naman below middle pa, I asked the radiator guy kung ano ibig sabihin noon, una sabi niya ewan, then sinabi niya na nag rereact daw yung naiwang coolant sa loob ng engine sa water na nilalagay namin. after 20 mins of IDLING, and pouring water, nawala din naman yung FROTH, then nagcomment yung isang guy, na bumukas na daw yung "thermostat" again, normal parameters pa yung temp. i grew disconcerted, so after driving for a while and parking for 2hrs, i went and tested it again, i removed the radiator cap and revved the engine, thankfully wala naman yung froth. and the temp is normal.
thanks sirs!
