Ganito ang gawin mosa 200mL.. kuha ka ng 200 mL na distilled water then lagay mo both sa coolant-reservoir/ spill container. Problem solved..
Hindi mo kelangan mag add ng coolant not unless may defect ang cooling system. Almost closed-loop system yan, magbabawas lang kung may leak. Kung magbabawas man siguro 150mL lang for the entire 40k kms kita modin kaagad kung magbabawas without opening rad cap by looking at the reservoir..
After 40k kms drain & flush the radiator, engine block, and coolant reservoir. Pour new coolant same 50:50 ratio. Remember chemical degrade when subjected to heat so kung severe use mas madalas kadin magpapalit. Ang magdedetrmine kung kelan ka magpapalit depende sa runtime ng engine mo. For ordinary use, 40k kms. Kung bihira gamitin ang sasakyan or naka garahe lang, coolant should last along with the engine.
