Results 1 to 10 of 34
June 29th, 2005 05:32 PM #1
may leak sa ibabaw nang radiator ko very visible sya kahit gamit mo pag inangat mo yung hood at tingnan yung ibabaw dunsa mga ngipin na nakakabit basabasa sya.
Honda Civic ang car ko ang problema plastic ibabaw nun
Ano ang dapat ko gawin
June 29th, 2005 05:36 PM #2
ung EK ko dati nagkaroon ng leak same dyan, pina-epoxy ng owner ok naman daw ilang months na. ewan anong epoxy gnamit nya pero i dont recommend that..
June 29th, 2005 05:53 PM #3
Clavel,
Hindi ko sure kung napapalitan ng tanso yung ibabaw. IMO, kung tapal gagawin dyan, babalik at babalik din ang leak. Better check with Radiator shops na lang kung magagawan ng ibang paraan.
There are shops that sell surplus/used honda orig radiator between 1 to 1.5K. Pwede na di ba?
June 29th, 2005 06:10 PM #4
yah. kung may benta nang surplus na 1 to 1.5k ok na kasi pa overhaul pa lang 500 na
evercool kaya maganda kaya yun at kung mga magkano
- Oct 2004
- 132
June 29th, 2005 08:15 PM #5Naku.. ganyan din problema ko nuon(97 vti). Dyan rin nagleak forgot what kind of metal that is tapos plastic un ibabaw... I guess it just dont stick.. bwis*t naabutan kami overheat from pangasinan to manila. So un stop and refill H2O from tarlac to manila. un 3 hrs na byahe naging 10 hrs. Hasle talaga..
Back to the topic.. pinapalitan ko orig costs 6500 plus 200 sa cap. (ewan kung naloko ako pero ayaw ko nang isipin). Tanso na un pati un asa ibabaw kaya didikit talaga and its repairable sa mga suking radiator shops.
Pero kung tatanungin ako ngyon.. i'll buy that evercool radiator.. its actually a radiator upgrade not a replacement. Between 8-15k ata un. Correct me if im wrong. Also may thread na un d2. :-)
June 29th, 2005 08:43 PM #6
Mukhang maganda naman ang feedback sa evercool, pero di kaya medyo may kamahalan.
If budget is in question, hanap ka na lang ng surplus. Marami ka namang pagpipilian. Try checking other threads for more info.
June 29th, 2005 09:20 PM #7
Saan ka ba located kasi dito sa cavite sa bandang imus SOFIA ang tawag sa lugar maraming surplus and new na radiator for civic.
June 29th, 2005 10:59 PM #8
Originally Posted by CLAVEL3699
June 29th, 2005 11:13 PM #9
June 30th, 2005 12:33 AM #10
Originally Posted by falken
mga magkano kaya yun. Salamat
yung plastic lang sa ibabaw ang papalitan?
The Yokohama BluEarths notoriously break down as you use them. I guess something in their...
Finding the Best Tire for You
