Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Oct 2005
    Mga sir, tulong naman...iyong civic ko,, iyong uper radiator hose ay "naimpis"
    na paran may hangin sa loob. Kaya tendency ay nataas ang temp para mag overheat. Specially pag naka park at bukas iyong makina.
    Can you help us your idea and suggestion kung anu ang problema.
    thanks in advance .....
  2. #2
    pag may parang hangin sa loob ng hose, naku, pacheck mo yang makina mo.. pag binuksan mo yung radiator car (when cold) and start the engine, malakas ba dumudura ng tubig from the cap?
    ang radiator hose kasi po sa pagkakaalam ko di numinipis pero kumukunat/ nagkaka-crack...check mo hosed mo na din for cracks.
    have your radiator top and bottom overhauls(remove the accumilated rust inside)
    Jul 2006
    It just needs to be burped para mawala yung hangin. Usually may bleed screw yan, like a small screw you can remove na located at the highest level ng cooling system.
    Oct 2005
    sir di naman siya madalas nag hihitemp. ang situation is ... pag nakapark sometimes nag hihightem on ang engine.
    pag naman inoff na iyong engine ..you will notice iyong upper hose ay slightly naka-impis or nak vacuum. pag open mo ng radiator cup may maririnig ka na paran hinihigop at iyon hose ay back to normal.
    pag naman start mo engine hindi naman siya bumubulwak......???
    any other ideas or diagnose ?????
    thanks po in advance
    Oct 2005
    sir Mbiege; parang ganoon nga na needs to burb, kasi may hangin sa loob.
    actually na drain na namin totaly at pinalitan na ng water at coolant.
    sir sa located itong screw na for bleed. and model ng car ay honda civic 2000.
    thanks in advance.
    Sep 2004
    Kung may hangin sa loob ng radiator/cooling system, then it means may singaw sa makina, di ba? Pa-compression check mo, one of the cylinders may have a leak.
    Jul 2006
    Ah ganun pala, parang it gets sucked?
    Radiator cap yan bro.
    Oct 2005
    galactus > doe's it mean possible for top over haul para macheck.
    Mbeige > what do you mean radiator cup ? do you mean palitan ko na lang iyong cup muna ?
    What if i bleed /drain ko muna even iyong mga hose coming from radiator then plug ko ulit after total drain para iyong hangin mawala. Then refill the new coolant and water. Do you think this will work. ???? any other possible solution ?
    thanks po sa mga ideas ninyon at sa mga other tiskoter please help and advise.
    Jun 2006
    Quote Originally Posted by Galactus View Post
    Sana hindi naman. Sabi niya drain and fill niya ng water and coolant yung rad. Baka doon galing yung hangin. Burp and bleed air 1st baka makuha na. Although a compression test won't hurt. pwede rin pa pressure test yung radiator. Tama ba na kung walang leak ang radiator ibig sabihin ok din ang cylinder head gasket?
    Oct 2005
    Guys ..ok na iyon ride ko ...kaya naimpis ..may problema iyong rad cup ko... kaya pinalitan ko lang... ok na ......
    so isa ring pa la sa factor kaya nagkakaganoon ang rad hose pag sira ang cup.
    thanks ....
Radiator hose "Naimpis"  pls .. help ?
