Results 41 to 50 of 58
September 29th, 2003 10:20 AM #41
guys,
i had mine flushed over the weekend (DIY lang), following the step-by-step procedures you all suggested! But i have this problem now: it appears na meron ng tagas yung cooling system ko as evidenced by a pool of water sa ilalim ng radiator while parked overnight, so nagdagdag ako ng distilled water, nakaubos yung radiator lang (did not touched the reserve tank) ng half a bottle of the 750ml plastic bottle. Sinalat ko yung radiator plug, medyo basa nga pero mahigpit naman yung lock, but the strange thing is while on my way to the office, i stopped and checked the radiator plug once more.... TUYO naman sya...
Please help naman! baka ma i save pa radiator ko from overhaul! tsaka yung wallet ko!
October 1st, 2003 10:09 PM #43Originally posted by gab0105
yung kotse kasi ni misis pag uwi parati ring malapit na sa mag o overheat buti na lang umaabot sa bahay kailangan ko na rin kaya papalitan ng coolant kasi wala namang mga leak ang mga host ano kaya reason yung coolant dalawang taon ko na siguro napalitan. yung thermostat kaya kailangan ko na rin patingin. malamig na kasi dito sa amin fall na baka masiraan pa mahirap namaraming salamt mga tsikot people.
Try having your auxillary fan checked at baka po mahina na ikot. Mostly dito po ang source ng problems. If ok naman then the culprit may be:
1. Thermostat
2. Water pump
3. Baradong Cooling fins ng radiator
4. Kung nababawasan ang coolant then baka may leak sa hoses or a defective radiator cap.
Have your cooling system checked by a mechanic so your problem could be solved. Goodluck.
October 1st, 2003 10:18 PM #44Originally posted by crossback
guys,
Try checking daily kung nagdadagdag kayo palagi ng water/coolant.
If Yes, then may tagas nga po iyon. Since ok naman drain plug ninyo then the culprit may be one of your radiator hoses. Use a flashlight to check the hoses individually. Since most coolants are colored green, pag nagkakulay ang isang hose ay most probably dito ang source. You may also inspect it while the engine is running. Malakas ang sirit ng coolant sa leak site since the coolant is circulating and under pressure. Check also your radiator cap at baka may singaw na din as coolant could esacape throuh this route.
If No, then most probably the pool of water you described may hav come from the condensed water from your A/C. Normal lang ito. ;)
Have your cooling system checked by a mechanic just to be sure. Goodluck.Last edited by roydok; October 1st, 2003 at 10:21 PM.
October 2nd, 2003 12:11 AM #45
thx sir roydok,
daily nga po ako naglalagay, mga 1/4 to 1/2 of the 750ml distilled bottle every morning. tapos napansin ko pong laging may trace ng coolant sa opening ng coolant reserve tank, pati surroundings nung reserve tank may trace of coolant din, nababawasan din yung laman ng reserve tank!
all other areas are clear! radiator cap kaya?
October 2nd, 2003 12:24 PM #46Originally posted by wiretap_md
If you really want a really good flushing for your engine block and radiator, treat it to a LAVRAMON experience. Its a machine that is connected between the return hoses from your engine to the radiator. The machine is turned on and then a powerful turbulent stream flow is produced and recirculated throughout the whole cooling system. This is done for about 30 minutes. Your engine remains off. Tanggal talaga lahat ng rust and debris! I believe Mancor Caltex service station along E. Rodriguez has this machine.
October 3rd, 2003 12:24 AM #47Originally posted by crossback
thx sir roydok,
Pwede pong sa radiator cap or sa hose connecting your reservoir to your radiator cap inlet. Maganda pong ma-check ng inyong suking mechanic just to be sure. Goodluck.
October 3rd, 2003 01:31 AM #48
nagpalit ako coolant kanina. may nabili ako sa eldoado mitsubishi premixed na coolant sakto yung 1 gallon sa 4m40 engine kasama reservoir. 400+ price niya.
- Jan 2003
- 10
We previously supported Tapatalk for Google Play and iOS store, but both are unsupported right now....
tapatalk smart phone application.
