Results 1 to 12 of 12
    Aug 2013
    Please help po. I have a toyota altis 2003 model. Problem po is yung radiator fan di tumitigil. Supposedly mag oopen lang sya pag umabot na sa certain temperature diba? Ngayon po, pag sinusi mo kahit di pa bukas ang engine, bukas na yung fan agad. Ano po kaya ang problem nun? Any opinion? Thank you
    Jan 2009
    If it only started happening recently and you didn't had someone work on the electrical, it's likely a stuck relay.
    Check the relay box under the hood and pull out the radiator fan relay to have it tested.
    Jul 2006
    That, and/or a busted coolant temperature sensor. Is your engine temperature gauge still working?
    Aug 2013
    last time it had a problem is nung natuyuan ng freon ang aircon, so pina refill ko, then there was that situation where pagkalagay ng freon, di naman lumamig na, I thought may sira na talaga yung aircon. After a week tsaka ko ipapa check na sana sa iba shop, gumana naman ang aircon ng maayos na so di ko na po pinagawa. everything was running good, even this problem of mine in this forum. Then about a month after biglang nag ganyan na nga, di na tumigil si radiator fan. Anyway, salamat po sir, titignan ko nga yung relay na sinasabi nyo. Sana yun nga lang yun
    Aug 2013
    Sir sorry, di ko alam where that temp guage is, all I do kasi is open the aircon fan and thermostat (which are two different knobs), ok naman sya. Nagstop din naman yung thermostat pag malamig na, then it kicks in when needed. Pero yun ngang radiator fan ang di lang tumitigil.
    Thermoswitch.
    Aug 2013
    Quote Originally Posted by vhoiki View Post
    Ay sorry sir Lows, ngayon ko lang naisip, yung temp guage ng car. Thought it has something to do with the aircondition. Yes sir, yung temp guage works naman. ngayon nga mas mababa ang reading (ng konti), I assume because di nga tumitigil ang radiator fan to cool it down.
    Aug 2013
    Quote Originally Posted by [archie] View Post
    Thermoswitch.
    Nabasa ko nga itong lumang post here saying na nagpalit sya ng thermostat and thermoswitch, pero di pa din nag work, and had another opinion na fuse lang (or maybe relay yun) and dun naayos.
    http://tsikot.com/forums/other-troub...em-help-62769/
    Anyway yan na nga po lahat ang suspect ko, pero sana yung relay lang, it looks like yun ang mura lang for fix/replace
    Jul 2006
    Ok, looks like you got it all figured out. Bring your car to a competent electrician/mechanic for a thorough diagnosis. Good luck.
    Aug 2005
    Does this problem manifest from a cold start?
    If so, its an electrical issue. A stuck relay or a busted sensor probe.
    Aug 2013
    yes sir, cold start. you just switch the keys to on and on the fan goes, even if the engine is still not running (/haven't ran for the day).
    Still yet to check the relay. Thanks sir Evo.
    Feb 2009
Radiator Fan won't stop
