Results 1 to 5 of 5
    Aug 2003
    peeps, dapat ba siyang ireplace every 2 years, regardless of use/kms traveled? nagiging acidic daw siya pag tumagal?
    Jun 2006
    Don't know about the coolant turning acidic but usual recommendation ang replace every 2 years. May mga extra long life coolant na tumatagal ng 5 years ang life.
    May 2005
    its better to replace it every year, it's cheaper than a broken radiator. replacing it every year will cause your radiator to last as long as your car.
    madali lang naman ang pag-replace, it's also cheap even if you have it done in your suking shop.
    Aug 2003
    ok lang ba to just dump the old water/coolant down the drain?
    Nope. Dumping vehicle fluids down the drain is actually illegal. Though enforcement is lax, there is a good reason why such law exists.
    Coolant tastes 'good' to kids and animals but is very toxic. Coolant has been used by wives to poison their husbands (hinahalo sa drinks).
    You can drop them off at the gas station. I'm assuming most of them have facilities to take care of such substances since they are required by law. Even the water they use for carwash/engine wash has to go through filtration.
    I'm not sure about coolant turning acidic. But it does lose it's lubricating and anti-corrosive properties when it gets too old. This may be the reason for the corrosion and stuck up water pumps. Not the coolant itself.
radiator coolant replacement
