Results 1 to 17 of 17
    Aug 2006
    Mga sir, ano po ba ang recommended nyong radiator cap (aside from OEM) for honda 92? Yung circuit brand po ba ay ok din? TIA
    Quote Originally Posted by AcidBurn View Post
    in my opinion, radiator caps are not too hi-tech.. any brand of decent quality is ok.. i use whatever the guy at the parts store hands out.
    Federal Mogul with the same pressure ratings.
    Jul 2012
    +1 dr. d
    as long as tama ang pressure rating it will do its job
    Oct 2009
    mas maganda bumili ka sa surplusan ..kasi ung nabibiling tig 150 pesos..madaling maluto ung goma..base sa aking experience...result..kaunting init ng radiator,,pumupunta na dun sa reservor ung tubig sa radiator...
    naghanap ako ng orig na surplus,,,ayun naging normal ung tubig ng radiator ko...hindi na nagbabawas,,,
    nakuha ko lang ng 250 pesos...
    federal mogul,,at circiut ,,na try ko walang epek...
    sa surplus lang nakuntento radiator ko..
    federal mogul kung replacement.
    pero ako, gamit ko ngayon is OEM.
    if buyer knows how to examine surplus radiator caps for defects, then i suppose it's ok to get them. otherwise, brand new is "safer".
    Go OEM or at least with an OEM manufacturer (i.e. Denso).
    I've tried those Circuit brands before (no choice as the cap gave way and that's the only one i could get on the road) and it did not last too long. Radiator caps should also be changed every three years or so as the gasket and pressure rating deteriorates over time.
    Mar 2007
    Sir TS, makiride lang sa thread nyo ha, up ko lang po ito.
    Isang indication po ba na sira na ang rad cap kapag nirerev mo yung auto ay may bumabalik na konting tubig sa reserve? TY
    Aug 2005
    Quote Originally Posted by CarPainter View Post
    The radiator caps that are available here either come from Taiwan or China.
    Am more inclined for the Taiwanese-made ones, given their generally more evolved quality systems.
    Mar 2007
    Quote Originally Posted by EVO-V View Post
    Thanks for the infos sir.
    So isang indication po ba na sira na ang rad cap kapag nirerev yung auto ay may bumabalik na konting tubig sa reserve?
    Apr 2005
    Denso sells oem rad caps coolmate pasong tamo
    Sent from my iPhone using Tsikot Car Forums
    Aug 2005
    The function of the reservoir are 2 fold. First it is to store surplus coolant to last the duration between maintenance cycles. And second it is a surge tank that holds coolant that has overflowed from the radiator under high pressure conditions.
    When pressure normalizes, assuming it is a sealed system, the coolant will return back into the radiator.
    But if you are revving your engine and you have the cap off, and the radiator is boiling or gushing out from the filler neck, then you may have cylinder head issues that you may want to check up on especially if you're overheating.
    Nov 2006
    up ko lang, circuit brand na nabili ko 2 weeks lang deformed na agad yong gasket nya hanap muna ako ng bago today baka meron pang bukas na auto supply, happy new year to all tsikoters
    Quote Originally Posted by BRROOOMMMM View Post
    that's strange...
    are you overheating, hence the early deformation?
    but i'd like to know where we can get good quality caps with good quality silicon gasket..
    Aug 2005
    Get the Taiwan made caps.
    Apr 2009
    Denso or JKT brands
Radiator cap
