Results 11 to 20 of 29
November 25th, 2008 05:26 PM #11
as i know, replacing an OEM 1.1 spec to a 0.9 one will equate to premature opening of the radiator cap, in turn, may not good for your system. kaya better stick to whats indicated.
kung yung 1.1 mo, pinalitan mo ng 1.3 masama din kasi di agad narerelease yung pressure inside the cooling system.
Tsikot Member Rank 4
- 2,719
November 25th, 2008 05:54 PM #12medyo OT:
Bakit nauuso na yata sa mga bagong oto ang walang radiator cap? You refill coolant on the reservoir when its cold.
- Oct 2003
- 176
November 25th, 2008 06:35 PM #13
- 2,719
November 26th, 2008 04:47 AM #15
November 26th, 2008 08:26 AM #16
bro, ano na balita dito sa nabili mong genuine radiator cap? like i said, kung di na mapapalitan you can use it but observe carefully now if you have doubt then might as well look for the 1.1 bar. yes that with more pressure, your engine's cooling system can withstand more heat. however, with more pressure, you put more wear and tear on the engine cooling components. na inquire mo na rin ba sa casa?
like nickel68 pointed out maliit na difference lang yan, depende pa kung ilang percent ang coolant mo, naka 1.1 ka nga but only with 25% coolant so daig pa yan if naka 0.9 ka but with 50-75 or even 100% coolantang importante walang leak on your cap because that would mean very useless yan at back to zero pressure build-up niya just the same with mga pampaseherong jeepneys.
- Oct 2003
- 176
November 27th, 2008 05:56 AM #17As to update this thread (thanks XTO for reminding me)
It seems na yung water leak came from the 2 T-connectors connecting the vaporizer and the radiator line (i have an LPG kit installed) that greenfuel installed for my car. This T-connectors were replaced accordingly. Thank you greenfuel.
After reading this thread yesterday, sinubukan kong ibalik ang dating 1.1 na radiator cap and today it worked as it was expected. Normal lang. No overheating or loss of water whatsoever.
In using the .9 radiator cap for 1 month, wala akong makitang difference with regard to performance parang pareho lang with the 1.1
For now, i am using the old 1.1. Refilled the radiator with water and it seems puno pa ito. So no water was added.
My coolant mixture is 1liter of coolant is to 3liters of distilled water.
I hope i did not harm my car cooling system....
To everybody, thank you for posting in this thread. Very informative indeed.
November 27th, 2008 10:13 AM #18
- Feb 2008
- 46
Tsikot Member Rank 5
- Nov 2003
- 3,848
November 30th, 2008 03:52 PM #20all cooling systems are pressurized in some way or another. if not by a regular radiator cap, then with a cover sa reservoir that is capable of sealing the system properly (most new mercedes and bmw's)
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
