Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
    #21
    pag brand new ang sasakyan mo, lagyan mo ng coolant proteksyon kasi yan sa kalawang at rust remover pa. pag luma na yung radiator mo, posibling tumagas pag linagyan mo ng coolant kc manunuot yan sa mga corroded portion ng radiator, pag tagusan na yung corrosion cgurado tagas ang coolant mo. yung kotse ko seven years na hindi pa ako nag paayos ng radiator, walang halong tubig yung coolant ko, puro sya.
    Apr 2005
    #22
    if your radiator is denso, go to coolmate pasong tamo. look for boy santos. nangyari na sa akin yan.
    Dec 2004
    #23
    Quote Originally Posted by oknamlarry
    check out DANTE'S sa cor. ng DEL MONTE AVE. at BONIFACIO, QC, nasa harapan ng PETRON. just do not know the damage, pero mura doon and OK ang gawa. Pwede sila magfabricate ng radiator na gusto mo.
    yup, try dante's, had the top of my '98 accord's radiator replaced with a copper one just this week at their branch in antipolo (barrio mayamot, somewhere between soliven ave. and the old coca-cola plant). their main branch is in balintawak (as they said).
    they have A LOT of radiators on display so you won't miss them.
    2K ang charge for parts and labor. ok naman cause mukhang kabisado na nila pagpapalit (took less than an hour to finish the job), and eksakto yung replacement, pati yung holes and alignment, dun sa body ng radiator.
    actually saw nearby delta motors pick up a bunch of radiators they had repaired at dante's, apparently sa kanila rin nagpapagawa karamihan ng mga casa.
    Nov 2003
    #24
    use coolant in a 50-50 mixture.
    denso tops normally range between 1500 and 2k+.
    cheaper than a complete radiator but normally the whole radiator is better (plus you can sometimes upsize it pa)
radiator
