Results 1 to 9 of 9
- May 2012
- 20
May 15th, 2012 08:45 PM #1Hi Guys,
hiniram ko pajero ng tatay ko and i decided to clean up the engine bay. it so happen na tinanggal ko din reserve tank. ngayon nalilito ako kung saan sa dalawang tube ko ikakabit yung papuntang radiator cap ? inisip ko kasi ung maliit it serves as tunnel pabalik sa radiator pag kinulang ng tubig kaya sya tinawag na reserve ? sorry engot ko talaga grr. Thank you sa mga tutulong.
- Nov 2009
- 3,484
May 15th, 2012 09:27 PM #2Yung nasa kaliwa (barbed with standpipe) yan yung papunta sa rad cap, while the larger pipe is for overflow.
May 15th, 2012 10:29 PM #3
iyon tube ba naka connecta pababang tube, pinaka straw para mahigop ulit ang coolant.
- Nov 2009
- 3,484
May 15th, 2012 11:36 PM #4Stand-pipe yan para hindi hangin ang mahigop ng radiator during cooling.
Yung overflow naman kapag nag overheat ang radiator at napuno ang reservoir due to expansion, coolant will be forced to exit/dump into that hole.
- May 2012
- 20
- May 2012
- 20
- May 2012
- 20
May 16th, 2012 05:25 AM #7
May 16th, 2012 05:40 AM #8
kailangan may hose.. para yung overflow or yung steam na lalabas ay may pupuntahan.. baka kasi naka tapat yung labasan sa electrical parts. baka maka sira pa.
- Nov 2009
- 3,484
May 16th, 2012 07:51 AM #9OK lang basta wag mapunta sa electricals or other sensitive sensors ang coolant.
Minsan kung luma na ang coolant at natuyo sa paint or metal contacts nagkakaroon ng umido..
Ingat din baka dilaan ng alaga mong pusa ang natapon na coolant, dedbol yun. Matamis kasi ang coolant.
The serpentine belt is still okay, usual consumables (air filter, oifl filter, cabin filter) got...
Ford Everest 2015
