Results 1 to 10 of 10
    Feb 2009
    pede ba ang r-12 system charge ng 134-a freon?...
    kung hinde pede, ano dapat gawin para mag compatible ang 134-a freon sa r-12 system...
    thanks....
    [QUOTE=MaGnafl0w;1307901]pede ba ang r-12 system charge ng 134-a freon?...
    thanks....[/QUOTE
    i'm confused here
    akala ko may mga AC TECHS sa shop mo since you specialize in CAR AIRCON.
    PLEASE EXPLAIN ANG HABA NGA NG AD MO SA FORUM PARA SAAN BA YUN ?
    Apr 2008
    Quote Originally Posted by MaGnafl0w View Post
    thanks....
    Ang alam ko pwede, nagawa ko to dati sa 1990 corolla pero wala naman naging problema, wala na rin ako pinabago sa aircon system.
    Feb 2009
    * BAMBINO
    as you can see sir, question posted yesterday weekend, wala work, close shop ko, monday is holiday, kya wala pren me worker.
    since hinde ako aware... wala naman siguro masamang magtanong
    magnaflow , hindi masama ang magtanong kung hindi sigurado or hindi alam ang trouble or procedure but you're representing a professional AC SERVICE FACILITY . hahayaan mo na lang ba na malaman ng karamihan na incompetent ang shop mo?
    yes it was weekend ,pero hindi yan ang reason , you just let the rest of us know who's in charge . if i were you i should have phoned my top guy to answer these basic questions .
    if you want a professional advice why don't you get your shop registered with IATN ( all the techs in the world gather their thoughts together to help each other solving problems) and it's free.
  6. #6
    r-12 is r12... r-134a is r134a.. magkaiba yan... parang gasoline engine oil vs diesel engine oil! or dexron vs mercon vs diaqueen vs mercon5 vs alisson c-4 atfs.. di mo pwede paghaluin!
    maxima ko is converted to r134a an these are the summary of work:
    1. TOTAL FLUSH OF THE SYSTEM. These includes: compressor opening, flushing the pipes, evaporator,condenser/s. this is to remove ALL traces of r-12 oil.
    2. after flushing, include the cleaning of the evaporator,replace reciever/drier and expansion valves. check for leaks and reassemble the ac-system.. replacement of r-12 compressor oil to r 134a oil is done once put back together and after vacuuming the system.
    3. after replacing the oil, put the r134a in. remember, that r134a is thermally more efficient than r12.. kaya mas kautin ang lagay nun than r12. for instance, if 1/2 kl nilalagay mong r12, sa r134a, mostlikeky 1/3 - 400g ng r134a lang lalagay mo kasi mas nageexpand ang r134a than r12..pag masyadong maami, sisirain nyan o-rings mo.
    4. thats about it...
    Feb 2009
    * bambino...
    kaya nga d ba?.. d naman ako mag tatanong kung sigurado ako... at kung na contact ko ung techs ko d narin ako para mag post right?!
    and iba ung nalalaman ko sa nalalaman ng techs ko... 1st time ko na encounter, kaya d2 ako nag post... kase alam kong may makaka tulong sa akin.. hind un gaya ng ginagawa mo? d ba? out of topic naman kase... at bago mo pa sabihin mga bagay na yan inisip ko na...
    and hinde incompetent ung shop namin... wala akong naging masamang feedbacks sa mga customer namin... once ipinasok nila ung car nila, pag labas ng car repaired at ok na...
    and mas maganda na siguro ung NAGTANONG kesa nag AALAM ALAMAN...
    salamat po...
    search the internet; key word: AC RETROFIT
    magnaflow ,
    advice ko lang kung wala ka talagang basics sa CAR AC ,huwag mo nang i touch yung car para walang maging prublema.
    hintayin mo na lang yung mga techs mo para sigurado.
    complicated ang retrofitting .it takes an experienced tech to tackle this.
    Feb 2009
    * BAMBINO
    as i said sir... bago nyo pa sir sabhin mga bagay na yan, naisip at ginawa ko na.
    salmat sa concern...
    ang sakin lang, i posted this thread to help me and find ways, hindi po ung criticize...
    * ALL
    thanks po sa mga nag bibigay ng idea, at sa hindi naman, salamat narin po...
Q: r-12 system pede charge ng 134-a?
