Results 1 to 5 of 5
- Feb 2008
- 577
November 11th, 2009 10:54 AM #1i had my dash stripped for general cleaning at sinabay ko naring lahat ng aircon components - blower, duct, evap. i noticed that some of the foam seals are either too compressed or crumbling into pieces.
before reinstallation, pwede ba kahit anong foam ang gamitin dito? any other ideas na locally available?
November 11th, 2009 02:06 PM #2
November 11th, 2009 04:55 PM #3
sir DIY lang po ba pagtanggal no ng dash or may shop kayo na pinagpagawan?im planning to take it out din for cleaning eh..thanks!
November 11th, 2009 05:39 PM #4
victorIOUS,
removing the dashboard is straight forward, no trick no fuzz. remove the instrument cluster first and disconnect the wires connected to it and disconnect the speedometer/odometer cable (mechanical type). then remove the bezel for the radio. be gentle on these plastic components as most of these have gone brittle from the scorching heat and the u.v. rays of the sun. remember how many, type and installation of the screws. reassembly is just the reverse of removal thir.
jick
- Feb 2008
- 577
November 12th, 2009 11:34 AM #5yup, diy ako. car is lancer pizza. as much as possible kasi ayoko pagawa kotse unless talgang di ko kaya or wala akong gamit (e.g. aircon flushing, vacuum, freon charging)
here are my suggestions if you want to strip your dash.
- be gentle on clips and other plastic parts
- if you don't have the proper prying tools, use a flathead screwdriver with soft cloth for prying
- remember where you took off a bolt or screw, how? after taking it out, return it where you took it off.
- when returning bolts and screws, turn them first ccw and feel for a slight depression before you turn cw
- use fingers first in initial turning of bolts and screws
- do not overtighten
- use common sense
- there are some things better left assembled. some disassembly tasks are not worth the effort.
if you don't have the service manual or if the service manual is still obscure, a digital camera is very helpful.
high idle RPM at engine start
