Results 21 to 27 of 27
- Nov 2005
- 57
August 27th, 2009 12:31 PM #21panu ba malalaman eh wala glass ako makita and talaga bang nauubos ang freon kahit wala leak or mauubus lang pag may leak?dati malamig un capsule eh nagpapawis pa pag hinawakan ko ngaun wala na...pero may natulo pa rin na tubig sa ilalim na malamig...pero ung buga nya pag naandar lang nalamig pero hindi na nya kaya palamigin buo sakyan even sagad termo.......ung mga tubo d din malamig....
August 27th, 2009 03:19 PM #22
mechanixx,
how does a triage nurse know the baby's body temperature is a bit too high? does she use a thermometer? in your case, you need a manifold gauge to observe the pressures of the high side (about 270 psi on your ambient temperature range) and the low side ( about 27- 30 psi on the same ambient). then, if the shop has a PTC (pressure/temperature chart), they will be able to see the corresponding temperature basing on the pressure. bring your car to someone who knows what he is doing.
jick
- Aug 2009
- 31
August 27th, 2009 06:47 PM #23
August 27th, 2009 07:52 PM #24
dealermate,
bambino is absolutely right assuming the climate control system is factory installed with OEM parts. but in the philippine automotive service industry where the parts market is saturated with fake, substandard, made in who knows where and the "pwede na 'yan" parts, it does not apply. that's the reason why i recommended the pressure/temperature way of determining the right amount of refrigerant. the objective is to have the cabin temperature lower than the average human body temperature by around 20 degrees fahrenheit or around 65 to 70 degrees (humans normally have about 87 to 90 degrees of body temperature). what we are trying to do is to put the cabin within comfort zone.
jick
October 25th, 2010 12:22 AM #25
mga sir tnong lang po mern po ba kau alam na aircon shop na nag titimbang ng freon instead na nag babase lng sa gauge? prang mas accurate pag tinitmbang ang freon. anyone here na nkakaalm let me know thanks.
- Aug 2008
- 65
October 25th, 2010 09:52 AM #26Meron akong alam, kaya lang outside Metro Manila, nasa Quezon Province pa sila.
http://img193.imageshack.us/img193/7986/img0003nk.jpg
heto yung setup nila.
- Nov 2007
- 164
October 27th, 2010 01:39 PM #27
Xiaomi E-Car
