Results 1 to 4 of 4
September 30th, 2011 08:13 PM #1
Good day fellow tsikot members,
I just would like to ask what will be the effect to the car engine of a radiator fan spinning in reverse? I suddenly found out that my uncle's car radiator fan (puller fan) spin in reverse which instead of pulling air from the grille to the hood, it push air outside the grille from the radiator.
October 1st, 2011 07:35 PM #2
October 1st, 2011 08:14 PM #3
Yes, reverse polarity lang para mabago yung ikot, usually dapat papasok yung hangin sa loob galing sa labas, pag tumatakbo yan hirap yung fan kase baligtad yung ikot salungat sa hangin
October 1st, 2011 10:29 PM #4
thanks po sa tips, ok na, i just followed what you said masters, I reversed the polarity + and -, sabi ng uncle ko nagkamali daw siguro yung mechanic sa pag-install nung fan na huling pinagawan niya ng radiator a week ago, parehas kasi black yung wire ng + and -. kaya pala nagtataka ako nataas ang rpm (1000rpm, from 800rpm) niya in long drives saka nag-eexceed sa kalahati yung temperature (above 1/2) kala ko engine problem, yun pala reverse spin radiator fan lang pala problema, ngayon ok, swabe na ulit.
Monk-owned R53
