Originally Posted by
zeagle
Actually its not only the oil that is different from an R12/R134a compressor. The major difference there are the shaft seal and gaskets. R134a molecules are smaller. If you just replace the oil of an R12 compressor with R134a oil without changing the shaft seal, eventually the refrigerant will leak out. Though it will take years I think for it to completely dry out.
As for taking care of your compressor, just make sure that you don't just refill the refrigerant. If you need to refill the refrigerant, there is leak. Make sure you resolve the source instead of just regularly refilling it. Also, have the clutch bearing replaced once you start hearing noise. If you don't, the hub might get damaged. Hirap pa naman to find a replacement hub for some compressors. Sometimes you have no choice but to change the whole thing.
