Quote Originally Posted by groucho View Post
boybi, how did you flush out the old coolant? Did you just drain it via the plug at the bottom of the radiator, or did you have to execute some fancier maneuver to totally drain out the old coolant? Makes a difference to me, kasi eh. I can probably DIY the change in coolant if I just drain the old fluid from the plug. However, I hesitate disassembling anything else for a more thorough job because I am not that mechanically adept.
Okay lang ba to just drain the old coolant from the drain plug? Or is that not enough?
same question here...
