Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 98
    Jul 2006
    #61
    The a/c of our 1995 Ford Contour SE still works up to now with proper care and maintenance. It's not quite as quick to cool down as the much newer Sonata. But, it still can handle the desert climate. As far as I now, all major components are still original.
    I'd guess, any a/c unit should be able to cool down decently as long as proper maintenance is followed.
    When I had my AC fixed, the only thing they replaced was a bad leaking shrader valve (pito) on the high port. Nagpalagay ako ng R12 (here in the US it's still OK) and it's very cold kahit minimal setting, and mind you, this is an original system in a 24 year old car.
    #62
    sabi sakin, Nissan daw has good AC system
    Nov 2006
    #63
    we'll nissan dominates....
    #64
    Quote Originally Posted by 3sgTe View Post
    db dahil brand new?? kc sabi nissan even if older models lakas ac pa rin...
    +1. 97 model nissan ko pero lamig pa rin. lalo na ngayon, kakapalinis ko pa lang kila mang mario. imagine this setting: time: 12 noon. outside temp: 36 deg cabin temp before A/C: almost 50 deg "ON" ko a/c at these settings: 28 deg, number 3 fan speed. after ten minutes siguro, ibabalik ko na sa low yung fan speed, lamig na e.
    kaya pala malakas din fuel consumption?
    +1 ulit. tama talaga to.
    May 2004
    #65
    Hilander ko 97 model ang lamig ng aircon... termostat ko minimum lang tapos number 2 lang blower ko sa harap and 1 sa likod... kahit anong init kaya pa rin... pag gabi hindi ko na kaya lamig...
    Jul 2003
    #66
    yah! that's TRUE Nissan is the best AC System.
    I have a 87 box type sentra before, have a nice AC. This car if the AC engage the temp. is upto 1/4 but if it is OFF it moves to 1/2. Thats my experienced
    Mar 2005
    #67
    Yeah nissan lakas talaga ng aircon. I happen to have a 96 S3 a couple of years ago and malakas talaga. One time I had the evaporator cleaned and kaya pala malakas, ang laki ng evap compared to other cars.
    My civic SiR has no tint pero malakas naman din ang aircon. What I did is I disabled the heater. I plugged the water passage on the engine block and now my a/c runs cool. kahit wlang tint malamig pa din.
    Jun 2005
    #68
    Same comments on the A/C system ng Sentra/Sunny Series III. It was the coolest A/C in its time.
    With that, I do want to see if this still applies to NEWER Nissan vehicles (ie. Murano and Teana). Sana we can test this out sa Motor Show.
    In other news, I'm surprised sa A/C system ng Toyota Previa (3G).
    Ang lamig niya when you just set it to lowest fan speed. Set it to 4-speed (maximum in most cars) then you feel like you're in Alaska or Antartica.....
    But surprisingly, puwede pala 'to isagad even further with 7-speeds sa FAN BLOWER. I haven't seen any car with so many fan speeds in my entire life (being used to max * 4-speeds) but I can say that it's freezing inside during last year's test drive ng kotse.
    Wow!!!, walang duda na talagang sub-zero na ang pakiramdam
    Apr 2006
    #69
    hyundai starex, malamig talaga!!!
    Nov 2006
    #70
    Quote Originally Posted by raquino View Post
    old one or the new one?? kung yung luma...uhmm.. ewan
    Mar 2005
    #71
    kung yan lang pala ang expertise ng Nissan, dapat kalaban nyan Condura, carrier, whirpool hahaha
    #72
    I tried also temperature testing ng car ko kahapon, toyota corolla 97 model,it don't have tint, five (5) of us is inside the car, the ambient temperature is 36 deg.C, I set the thermostat to 3/4 only and the blower is set at #2. I put an analog thermometer sa tapat ng A/C grills sa center console, after two (2) mins. nag-automatic off na ang condenser fan, the temperatures that registered is 15degC. sa A/C grills, while inside temperature is 21.5 deg.C.
    #73
    Quote Originally Posted by hubertq34 View Post
    pati ung blower ng a/c pwede gamitin to cooldown the engine.
    kung 'di ako nagkakamali, nakita ko sa auto ng isang friend ko 'di ko na matandaan kung ano'ng auto yun meron siyang parang radiator sa loob kung sa'n may tube na nakakabit sa makina daanan ng tubig, pag inislide sa heater yung air-con, do'n dumadaan sa maliit na radiator sa loob ng cabin yung hangin kaya umiinit ang hangin. In effect aside from the engine bay radiator, nakakapagpalamig din yung 'in-cabin radiator' or yung heater...
    #74
    Quote Originally Posted by Blackraven View Post
    CR-V marami ring fan speeds more than four 'di ba?
    Jul 2006
    #75
    Quote Originally Posted by jezreel View Post
    To determine if the AC is working properly, the temperature at the AC vents should be half of the temperature outside the vehicle. It looks like yours is working perfectly.
    I was able to make mine read 6 deg C when running at the coldest setting when temperatures here were 20's, though on a regular day (24C) the temperature at the AC vents would be ~10-12C, just right. The lower the blower speed, the colder it will get. The higher blower speed is just to get all the warm, humid air out of the system and quickly replenish it with cool, dry air from the AC. Kaya masmalamig kapag lower blower settings ang ginamit, dahil yung air is denser when it hits your skin and therefore, colder.
    And this is with good old R12 refrigerant in a 24yo car, possibly with the original compressor too.
    Nov 2006
    #76
    Quote Originally Posted by oldblue View Post
    hehehehe.. aus.. pwede na rin..
    #77
    Eto malamig. Hindi pa kailangan ng freon.
    Apr 2006
    #78
    mines the 2001 model, no problem with a/c mostly 1 lang fan speed and 3/4 thermostat. the hew models nasakyan ko malamig din.
    #79
    among all my cars the most consistent a/c performer is my ae92. from the time it was purchased till today.. never been serviced. hard to believe but its true.
    Nov 2006
    #80
    nice ride...
post the vehicle w/c has d best airconditioning system during the hot summer days..
