Results 1 to 10 of 22
Toyota is my choice
- Aug 2005
- 2,063
September 12th, 2005 01:41 AM #1Gud am mga tsikoters, I have my problem with my original radiator plastic/fiber glass radiator kasi may rust sa inside tapos di pa nman mag overheat kasi coolant gamit ko and battery water na purified gamit ko tapos nag flush na din ako..
palitan kuna po ba or palitan ko ng brandnew or surplus magakano po ba? tips lng po.. ty ha!
September 12th, 2005 07:52 AM #2
Brand new about P16,000. Surplus mga P3,500. No labor yet. I think your radiator is still OK.
Toyota is my choice
- Aug 2005
- 2,063
September 12th, 2005 01:54 PM #4Originally Posted by j_avonni
Toyota is my choice
- Aug 2005
- 2,063
September 12th, 2005 01:55 PM #5Originally Posted by j_avonni
teka sa-an yong thermostat?
September 12th, 2005 02:17 PM #6
dont change it to a metal top, kung magoverheat ka cylinder head agad ang masisira.
DENSO repairs the radiator tops, if di kaya, mag surplus ka nalang, or di padin, just get an evercool radiator.
September 12th, 2005 02:27 PM #7
there's a good radiator repair guy in our area, tondo, he's very good in overhauling radiators even the one's with a plastic top... cost would be less than 1k.
or you may try dallas in tomas morato and have your radiator descaled.. i tried them out just recently, they did a fairly decent job in getting my rad cleaned.. but i think it would had been more cleaner if i just opted to have it overhauled...
September 12th, 2005 02:46 PM #8
If I understand you right, there is no problem with the upper tank. Its just that there is rust developing inside. If that is the case, Denso can overhaul your radiator with just the upper packing (gasket) to be replaced. If the upper tank is damaged, total cost of repair including parts will just cost you around P2,400.00. You can go to Denso in Pasong Tamo.
September 12th, 2005 09:18 PM #9
me for sale ako na radiator for 96 XE. baka interested ka. good condition to and i can provide you with a limited warranty.
Toyota is my choice
- Aug 2005
- 2,063
September 12th, 2005 11:50 PM #10Originally Posted by theveed
wow.. pre.. galing mo talaga.. number 1. thank you ha. di pala maganda yong metal top radiator at mabuti pa din tong sakin kaya nga lang sabi kasi ng mechanic di daw pwde ma clean up ang rust kasi orig daw at baka masira.. maintain ko nlang cguro to at parati kung lng pa flush kasi okey pa din eh wlang bara..
ano po ba other maintenance para ma maintain ko muna tong rusted radiator?
"thermostat" ano po yan kuya?
salamat sa reply!
Im from cebu pala. sory di ko nasabi.
Anong Chinese brand na ba ang available sa market? Yung Leoch brand may nakita na ko post sa FB....
