Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
    #21
    Sir Odell,
    Do you mean pag "on" mo ng AC sa umaga (coldstart)?? Well, anecdotically, may 2 explanation ako dyan from experience- the expansion valve problem at the rear AC, and leak in the hoses. Pag leak in the hose, you'd notice that "as time goes by", lumiliit ang length of time na malamig siya until totally di na siya malamig.
    Of course, this is just based on my limited experience--> with my vehicles...
    Sir KC, mura lang yata expansion valve, wala pa yata P500, pero karga ka uli freon.
    Feb 2005
    #22
    Quote Originally Posted by KCboy
    zeagle,
    ask ko lang, tatapon ba yung refrigirant ko if they adjusted my expansion valve?
    Dude kung may recovery machine yung shop puedeng ma save refrigerant mo. Kaya lang sa laganap ng adulterated refrigerant, maiigi pang palitan mo na baka yan ang one of the cause. Make sure lang yung ipapalit na refrigerant branded.
    Feb 2005
    #23
    Quote Originally Posted by odell
    panu pag un malamig naman siya pag ccoldstart... pero pag un temp niya half na tapos pag on mo aircon.. wla ng lamig...
    Odell try mo ito. Mag mainit na yung temperature, hose running water sa condenser mo. Paglumamig aircon mo ulit and problema high pressure ang system mo pagmainit na makina. Pa check mo fan or condenser mo. Baka barado ang condenser.
    Jan 2009
    #24
    My pajero aircondition once idling di sya bugnaw, but once i-revolution nako mubugnaw sya, and much-much more better if nagdagan na. what would be parts na ilisan and estimate costs. thanks. auxuliary fan and freon are both ok.
    Jan 2009
    #25
    My pajero aircondition once idling di sya malamig, but once i-revolution ko lalamig sya, and much-much more better if nakatakbo na. what would be parts na palitan and estimate costs. thanks. auxuliary fan and freon are both ok.
    Aug 2008
    #26
    sir, if may time kayo at malapit lang kayo s makati try to drop by s shop namin located at 2251 don chino roces ave., makati city. u can call us at 8923494 luk for ronald. by the way, my shop name is EMPIRE COOL.
pajero aircon
