If you've already checked your radiator and fans and both are working well, go and look at your thermostat (baka stuck nga so when the engine is running hard, coolant flow isnt optimal anymore), and the water pump. I'd suggest against using the car too much kung umiinit as you might end up with a cracked engine block (a bigger pain in the *ss).
