Mga boss thank you sa mga inputs. i did bring my car yesterday sa mekaniko to check on it. sinabi ko na nagooverheat yung oto. what they did agad is to have a compression test and leak test ata yun. they found out na bagsak daw. inopen nila yung engine cover then tanggal spark plug then may gauge sila na ginamit. sbi sken top overhaul na daw kailangan. but they didnt explain tapos what i did is lumipat ako sa isang shop ulet, then pina check ko. ang ginawa nung mekaniko is use a bottled water then nilagay nya yung hose nang reservoir ko tapos ni rev nila then may bubbles dun sa bottled water. sabi sken ulet kailangan nang top overhaul. kailangan daw palitan yung vavle seal, vavle guide and head gasket. pasensya na mga boss. wala talaga ko alam pagdating sa makina. asking for some clarifications and explanations mga tsikoteers... thank you..
