Results 1 to 10 of 10
- Sep 2005
- 59
January 3rd, 2007 11:49 AM #1Mga bro I have this experience sa oto ko 7g Galant naka park ako engine at idle a/c off lumalagpas sa 1/2 yung temp before mag on ang aux fan. halos 3/4 na ang temp dun pa lang mag on ang aux fan sa radiator.Then balik na sa 1/2. Is this normal?Overheat na ba to? di naman nababawasan water. Delayed lang ang aux fan. Bago pa din sensor ko oem. Pag moving ok naman a little below 1/2 ang temp. Thanks!
- Sep 2005
- 59
January 3rd, 2007 12:04 PM #3Sir bago din water pump kasabay nung nagpa change ako timing belt about 8 mos ago.
- Sep 2005
- 59
- Nov 2006
- 299
January 3rd, 2007 03:30 PM #7unang gagawin mo e check mo muna yung temp sensor,kahit bago pa yan pag di naman din pinalitan yung connector eh baka coroded na,eh di sya masyadong makapick up ng signal dahil sa corrrotion na yan kung meron man,,and second, check mo yung thermostat baka busted na,..
January 3rd, 2007 03:32 PM #8
Tingin ko din yung thermoswitch.
- Sep 2005
- 59
January 3rd, 2007 04:15 PM #9
- Nov 2006
- 299
January 3rd, 2007 04:37 PM #10ang thermostat is a temperature sensitive device used in cooling system to control coolant flow in relation to temperature,kapag masyado na mainit ang engine at ito ay mag bibuild up ng pressure at ipupush na nya yung valve ng thermostat para magbigay daan sa tubig papuntang radiator and from radiator balik na naman sa engine block(paikot ikot lang),ang thermo switch naman or temp sensor na tinatawag ay nag monitor naman sa condition and irereport ito either sa computer or deretso sa cooling fan or auxiliary fan(voltage signal),,,....kaya kung busted na ang gasket(leak) ng thermostat maaring ito ang cause ng delayed sa fan to come on.
I agree. travelling by train is always the fastest way to travel. kami din dati sa Bangkok, we...
Makati Subway. Completion date: 2025
