Here's another thought. Your engine's cooling channels maybe clogged already.
Bossing hindi po normal yan. Kindly check your radiator kung nauubusan ng tubig. There are many factors why your car overheat like Pede my leak radiator(butas)sira aux fan, my leak hose, sira thermostat, barado radiator, nag leak radiator cap. Check mo din ung tubig baka kung malinaw pa or color kalawang. Hope this help. Good luck![]()
Boss pano po malalaman kung sira thermostat.. ok naman po yiung flow ng tubig sa radiator. Yung aux fan po pinaayos ko na.. makakatulong po ba pag ina overhaul ko yung radiator ko???
Pag kakabukas ko lng ng makina tahimik lang tunog niya pero after ng mga 20 mins umiingay xa parang may takatakatak na tunog sa makina
yah, radiator overhaul may do the trick, it will help clean the entire water channels and help removes rust and hard deposits, cheap price lang naman ang magpa-overhaul (around 600 - 1000php. afaik) comparing to get a new radiator, yung van namin ganyan din problema, the temp needle goes more than halfway though di pa naman overheat yung tipong mabilis lang umakyat agad yung temp. , nung-pinaoverhaul namin ayun, steady na lang lagi sa gitna di na siya lumalagpas ng kalahati.
Compared to an engine overhaul a radiator is cheap. This advocacy for "radiator overhaul" can only go so far as being a band aid solution.
Flush your cooling loop.
That "takatak" sound has numerous causes. Valve tappets being one of them, and given your car's age, your timing chain may have more slack in them than they should.
kung nag aircon ka at saka lang overheat,
check
speed and operation of auxiliary fan... (depende sa nakakabit sa inyo, pwedeng 2 step motor yan na pag nag aircon ka bibilis lalo ikot,...
if walang tabas o machining na ginawa sa head mo during the overhaul dapat wala nang overheat yan sir...
pag bumawas kasi sa head mo by machining increase onti temp reading nang engine...
dapat sir, magaling ang aircon shop na pinagdadalan nyo para less expense at hindi hit and miss...
