Results 1 to 10 of 10
March 8th, 2006 02:48 AM #1
2nd time na nag over heat hi-ace ko... 2L diesel makina... as in ubos ang tubig... ang hirap wala kaming makitang tulo o singaw sa radiator, the first time it happened after pinalamig at kinargahan ng tubig back to normal sya...
tonight 3 weeks after the first overheat... from raon to sta. mesa nag over heat ulit same thing happened simot ang tubig... after letting it cool and putting water normal na ulit...
every morning bago umalis driver checks water ang oil, puno naman daw palagi yung radiator nung buksan nya...pag naka park naman wala naman tulo pag alis ...
ok naman yung rad-fan... di pa naman malabot na parang kulang sa silicon oil
ano kaya problema nito???Last edited by impulzz; March 8th, 2006 at 02:59 AM.
- Jun 2004
- 1,311
March 8th, 2006 03:12 AM #2completely empty yung radiator?
wala naman kayang leak ang water pump nyan? (if applicable)
how about the radiator cap? wala naman signs ng leak sa cap?
March 8th, 2006 04:31 AM #3
A visual inspection can be misleading. To be sure that the radiator is full, pour water or dip a finger. Sometimes, there's a bubble or a pocket of air underneath the surface that makes it look like there's water.
March 8th, 2006 06:00 AM #4
Ganun din yun 93 corolla XE namin e, wala naman tulo pero nauubos yun tubig so kailangan fill up every week.
Toyota is my choice
- Aug 2005
- 2,063
March 8th, 2006 09:28 AM #5I cant say kung ano talaga cause nyan pero dapat pa check mo na kasi too much overheating can cause engine break down.
Tsikot Member Rank 5
- Nov 2003
- 3,848
Tsikot Member Rank 3
- Dec 2002
- 636
March 8th, 2006 11:02 AM #7Probably have a crack in a radiator hose that only shows when it's hot. Check engine oil if there's water mixed in.
March 8th, 2006 11:41 AM #8
to avoid air pockets, have someone rev the engine while you put water in the radiator...do it during mornings.
March 8th, 2006 12:44 PM #9
kung warped head ano symptoms? yun ba yung pag start bubulwak yung tubig ng radiator? this morning pag start ko may squeaking sound na parang bearing, hula ko yung water pump na ang may problema...
March 8th, 2006 12:54 PM #10
my mechanic just called.. he saw a very small leak at one of the water plugs near the lower hose... its so slow that leaked water evapoartes fast due to engine heat that when i open the engine to inspect i don't see wet spots ... hope it solves the problem... now back to observation period... hay
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
