how often do we change the thermostat of the cooling system (i.e. months, years or mileage reading)?
have installed one 82C MD997606 for a mitsubishi 4d56turbo. so far no overcooling on highways and overheating on traffic. operating temperatures is within the first and second line of the stock electric temp gage while 180 (82C) to just a bit higher than 200 F (93C) on the mechanical gage.
TIA
i dont know exactly the correct normal temp reading of diesel engines but based on your readings in gas engines that seems to be normal,i think but not sure youll be fine because the only time to replace thermostat is when it gets bad like stuck open,stuck close or weak spring and the only way to check it,is to take it out and test it.
by my knowledge, operating temperature of diesels is higher than their gas counterparts...since diesel is oil and does not vaporize easily as compared to gas thus a higher temp to be able to help in atomizing the diesel fuel oil.
