Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    Nov 2003
    evercool rads fit perfectly with the stock fans and bracketry
    that what you get from a one row radiator. on highway may ram air effect ka so your temp is lower because the air, and the water, cools your rad. when standstill your engine heats up due to the less volume, 1 row lang kasi, of water circulating in your engine. yun 2 rows mo malamang madumi lang..
    Aug 2005
    since you bought already a surplus rad bro you really need to overhaul it first before installing it..For me Ill go get a recon rad with a bronze type top and below.. and for your stock rad its 2 row then 2 row din para iwas overheat.. di kaya nya ang 1 row .. if denso yong orig rad mo tapos ang nag leak yong plastic top cover lng pwde nman ma repair yong with no scratch..
newly installed surplus radiator
