Results 1 to 13 of 13
    Aug 2005
    gud day, i've just installed a surplus radiator for my '96 vti A/T, it's a 1 row radiator. the one i removed was a 2 row rad. i really wanted an evercool 2 rows but my 6k budget was just right to buy a surplus rad, timing belt, head cover gasket, change oil and brake fluid and labor.
    my problem before was, my old rad has already a leak w/c started 2 weeks ago, it was already overhauled last december, so instead another overhauling it again i decided to buy a surplus, since it's a vti's stock rad i assume it will be as good as a 2 row evercool. now here's what i've noticed after a day passed:
    1. on my old rad whenever my speed goes 90kph up (A/C on) the temp starts rising, when i slow down the temp drops to normal. on my newly installed surplus rad, the situation is opposite, the temp stays to half mark even my speed goes 90kph up, but would suddenly start rising when i'm slowing down or when i'm fully stop (idle), what do u think is going wrong?
    2. from a fresh start in the morning (stays idle), i've noticed that the rad fan takes some 20mins before it starts rotating, up to a point that smoke gets out in the radiator but the temp gauge remains in half. in my old rad, u can't see smoke coming out of the radiator but it also takes 20mins before the rad fan starts to rotate. the fan's automatic mode is working and the fan rotates at high speed, and when the fan starts rotating, it's only when the smoke gets out. any idea?
    3. i've used a prestone coolant (green) on my surplus rad, and i've notice that the rad cap and even the coolant reservoir has some dirt like mud or clay. on my old radiator i only use a mineral water and i don't see that clay-like dirt on the cap. is this normal?
    sori for my lack of knowledge questions as i'm not fully aware or familiar of any technicality about car. i must admit too that at my age, there's still lot of things i don't know bout simple troubleshooting, all i know is drive. and here, in this forum (and other car forum) that i'm just learning and being educated from reading and posting.
    too bad that most of the mechanics here in our place (pangasinan) are not yet or they don't have yet a knowledge and skill operating internet online so at least they could read some very informative topics here that would help them be better mechanics.
    tnx for replies.
    it seems that the surplus rad you bought is dirty. the clay like dirt should not be there. try flushing the radiator to clean it.
    Feb 2005
    makisakay na rin mga sir ano pong say nyo sa mga reconditioned radiator na available sa mga radiator repair shops? is it better than the surplus rads na galing sa mga surplasan? i'm also planning to replace my rad soon...tia!
    As they say, chambahan lang talaga sa mga surplus rads. Maganda reviews sa Evercool tapos mura pa. I suggest dun ka na sa brand new.
    Apr 2006
    magkano ba ang radiator kapag di surplus? kahit idea lang sa price.
    mahirap talaga kapag surplus. ok lang sana kung side mirror lang yan.
    pero kung performing part ng tsikot, susugal ka na talaga diyan.
    some three years ago, i bought a brand new generic (walang brand, made of tanso/copper) 1 row radiator sa isang autosupply near bestcolt in banaue.
    the price then was P2,400.00.
    so far, OK naman ang cooling system ko hanggang ngayon.
    Jun 2006
    About 3 months ago I bought a brand new Evercool radiator for my Cefiro. About 7000 pesos, yung surplus mga 6800 yung orig ng casa 21000.
    Aug 2005
    pag bumili ka ba brand new evercool, me kasama na rin fan? mga magkano kaya ung para sa vti matic? (for those who purchased already)
    Kapag bumili ka Evercool rad, radiator lang sya walang fan. Got mine (EG manual) for P3,600. Mas mahal ng konti pag matic.
    Aug 2005
    Quote Originally Posted by typhoon
    ic, so ung nasa radiator ko na fan pwede na cguro dun sa evercool?
    Nov 2003
    evercool rads fit perfectly with the stock fans and bracketry
    that what you get from a one row radiator. on highway may ram air effect ka so your temp is lower because the air, and the water, cools your rad. when standstill your engine heats up due to the less volume, 1 row lang kasi, of water circulating in your engine. yun 2 rows mo malamang madumi lang..
    Aug 2005
    since you bought already a surplus rad bro you really need to overhaul it first before installing it..For me Ill go get a recon rad with a bronze type top and below.. and for your stock rad its 2 row then 2 row din para iwas overheat.. di kaya nya ang 1 row .. if denso yong orig rad mo tapos ang nag leak yong plastic top cover lng pwde nman ma repair yong with no scratch..
newly installed surplus radiator
