Results 1 to 16 of 16
    Jul 2012
    Hi Guru's,
    Need ko po ulit ng expert advise ninyo,
    Pina-tingin ko po kasi ang zz ko netong weekend, sabi nung tumingin, baka daw marumi ang aircon ko, nag-palit kasi ako compressor last november at netong february lang naramdaman na hindi kaya yung init kapag tanghali, baka daw hindi nilinis, nilalagyan pa daw chemical to kapag nililinis? Tama po ba yun?
    Sobrang lamig padin siya minsan sa gabi at umaga, sa tanghali talaga parang ang kunti lang nang lamig, pero may mafeel ka pero kunti lang talaga, kung meron man daw leak ay maliit lang, at okay naman daw ung compressor ko, ano tingin ninyo guys? For the quick fix eh nag-add ng freon, ayon malamig po siya, pero sabi nung naglagay eh kunti lang daw nilagay niya at kita naman daw na hindi siya ubos kasi lumalamig pa nga siya
    Tanong ko lang guys, meron bang shop na may electronic detect kung may leak nga, may free po ba? Kung wala po may idea kayo kung magkano?
    May 2004
    dito sa atin manual lang po ang pag check ng aircon leak... soup and water...
    ^ sopas at tubig?
    Jul 2011
    ^ yan ang bago ngayon, hindi mo alam. :dance1:
    Oct 2011
    soap and water lang pra tignan kung nagka bubbles sa copper tubing.
    Feb 2009
    there are four ways to check for leaks in the airconditioner loop. one, with soupand water solution sprayed to the suspected area. two, flourescent dye penetrant injected into the refrigerant area and use a black light (ultra violet light) to expose the leak. three, use an electronic leak detector (the most preferred method). and four, without refrigerant in the system (usually done after parts replacement), vacuum leak test by evacuating the system at least twenty minutes at around 29.5 inches of mercury, if the system holds vacuum, it usually means that the system is vacuum tight but not necessarily pressure tight. for the evaporator area, the soap and water method does not work, you usually can tell if the evaporator or its o-rings are leaking by the smell of the refrigerant that has mixed with moisture (smells like horse crap) at the registers or vent
    Quote Originally Posted by 1D4LV View Post
    ^ sopas at tubig?
    sorry OT grabe tawa ko dito di ko mapigil waaaaa!! :bounceD:
    Jun 2007
    buti nga hindi biscuit at kape ang sinagot....malamang mag condolence tayong lahat :D
    Jul 2003
    ewan ko, kung may leak yan, kahit malamig pa panahon di pa din yan lalamig. ang problem niyan malamang ay di kaya ng condenser na i-cool down ang
    refrigerant. o kaya mahina na ang andar ng condenser fan.
Leak Detection sa Aircon
