Need ko po ulit ng expert advise ninyo,
Pina-tingin ko po kasi ang zz ko netong weekend, sabi nung tumingin, baka daw marumi ang aircon ko, nag-palit kasi ako compressor last november at netong february lang naramdaman na hindi kaya yung init kapag tanghali, baka daw hindi nilinis, nilalagyan pa daw chemical to kapag nililinis? Tama po ba yun?
Sobrang lamig padin siya minsan sa gabi at umaga, sa tanghali talaga parang ang kunti lang nang lamig, pero may mafeel ka pero kunti lang talaga, kung meron man daw leak ay maliit lang, at okay naman daw ung compressor ko, ano tingin ninyo guys? For the quick fix eh nag-add ng freon, ayon malamig po siya, pero sabi nung naglagay eh kunti lang daw nilagay niya at kita naman daw na hindi siya ubos kasi lumalamig pa nga siya
Tanong ko lang guys, meron bang shop na may electronic detect kung may leak nga, may free po ba? Kung wala po may idea kayo kung magkano?
there are four ways to check for leaks in the airconditioner loop. one, with soupand water solution sprayed to the suspected area. two, flourescent dye penetrant injected into the refrigerant area and use a black light (ultra violet light) to expose the leak. three, use an electronic leak detector (the most preferred method). and four, without refrigerant in the system (usually done after parts replacement), vacuum leak test by evacuating the system at least twenty minutes at around 29.5 inches of mercury, if the system holds vacuum, it usually means that the system is vacuum tight but not necessarily pressure tight. for the evaporator area, the soap and water method does not work, you usually can tell if the evaporator or its o-rings are leaking by the smell of the refrigerant that has mixed with moisture (smells like horse crap) at the registers or vent
ewan ko, kung may leak yan, kahit malamig pa panahon di pa din yan lalamig. ang problem niyan malamang ay di kaya ng condenser na i-cool down ang
refrigerant. o kaya mahina na ang andar ng condenser fan.
ang ac kasi pag sobra or kulang ang freon kahit konti lang may epekto sa lamig...kung may ga karayom kang leak mawawala talaga lamig pag noon time and pag naka idle kalang(nakaparada)...
sa evaporator may ginagawang leak test bago ikabit (pagkatapos malinisan) ay lalagyan siya ng pressure then ilulubog sa tubig to see kung may magba-bubbles kailangan lang magaling ang tumingin at mapasensya(kung ga karayom lang butas minsan di kaagad limilitaw)...HTH
your car is equipped with a very small engine which can only be equipped with a small compressor and of course small components. the btu per hour should be commensurate to the cooling load and the size of the passenger compartment of the car. if the unit had a bigger unit, it will cool the car even when it is hot. compare your house with a small window type a/c that is not big enough, even if the unit is very efficient, its capacity does not suffice the cooling load
sorry mga guru's hindi po ako nakaonline for past days, naging busy po,
Ang dami talagang pwedeng dahilan neto,
by the way po, I have medium black 3M tint po, nag-try po ako ng soap and water way, pero wala ako nakitang bubbles. San po ba may electronic detection leak? How much po ba to? Munoz nga po pala ako nakatira. Sa ngayon po nung dinagdagan nang kunting freon kinakaya na po ng aircon ko yung init.
The quickest way to detect a leak is using a halogen leak detector. Its essentially a sniffing device that is calibrated for a particular gas/substance.
