ewan ko, kung may leak yan, kahit malamig pa panahon di pa din yan lalamig. ang problem niyan malamang ay di kaya ng condenser na i-cool down ang
refrigerant. o kaya mahina na ang andar ng condenser fan.
ang ac kasi pag sobra or kulang ang freon kahit konti lang may epekto sa lamig...kung may ga karayom kang leak mawawala talaga lamig pag noon time and pag naka idle kalang(nakaparada)...
sa evaporator may ginagawang leak test bago ikabit (pagkatapos malinisan) ay lalagyan siya ng pressure then ilulubog sa tubig to see kung may magba-bubbles kailangan lang magaling ang tumingin at mapasensya(kung ga karayom lang butas minsan di kaagad limilitaw)...HTH
your car is equipped with a very small engine which can only be equipped with a small compressor and of course small components. the btu per hour should be commensurate to the cooling load and the size of the passenger compartment of the car. if the unit had a bigger unit, it will cool the car even when it is hot. compare your house with a small window type a/c that is not big enough, even if the unit is very efficient, its capacity does not suffice the cooling load
sorry mga guru's hindi po ako nakaonline for past days, naging busy po,
Ang dami talagang pwedeng dahilan neto,
by the way po, I have medium black 3M tint po, nag-try po ako ng soap and water way, pero wala ako nakitang bubbles. San po ba may electronic detection leak? How much po ba to? Munoz nga po pala ako nakatira. Sa ngayon po nung dinagdagan nang kunting freon kinakaya na po ng aircon ko yung init.
The quickest way to detect a leak is using a halogen leak detector. Its essentially a sniffing device that is calibrated for a particular gas/substance.
