Results 1 to 20 of 23
    had a problem w/ my '06 sportivo's aircon last week. May times na nawawala lamig, pero bumabalik din(around 10-20secs walang lamig). I decided to have my aircon cleaned yesterday, ok naman yung linis, walang butas yung condenser(?) na 2(dual aircon), and okay naman karga ng freon. lumakas hangin and malamig sya, pero andun pa din yung intervals na nawawala yung lamig(10-20secs). what could be the problem po?
    The problem might be on your Valve and the Dryer, have it checked with your AC technician
    Aug 2010
    bro, try mo itaas ang setting ng thermostat, pag ganon pa rin either pressure switch or magnetic clutch. mura lang parts na nabanggit ko, nag papamahal lang diyan yun service fee, lalo na pag kailangan mag release ng refrigerant...
    Aug 2011
    Baka naman ang sira eh yung thermostat switch mismo? Check mo lang baka nawala na sa hinang.
    nacheck ba nung technician yung auxfan mo? baka mahina na ikot or malapit na masira... minsan eto rin cause ng pagkawala ng lamig ng aircon
    Binalik ko sa aircon shop yung sportivo and chineck yung freon, okay naman. chineck ng technician yung thermostat, ang sabi nya is nagyeyelo daw - something to do with nawawala wala yung kuryente sa thermostat, so inayos nya. Ala namang naging problema paguwi, pero nung ginamit ko nung gabi to fetch my mom-in-law, nawala yung lamig. Pag andar malamig sya, tapos after 10-15mins, nawala lamig, puro hangin na lang. Then on my way to work today, gumana naman sya ng maayos(QC-makati * rush hour).
    Ok naman Aux fan mga sir. Expansion valve? nagiging prob lang ata ito pag totally walang lamig na lumalabas or kulang yung lamig. In my case, pag gumagana yung aircon, malamig tlaga sya, and prob is nawawala yung lamig(minsan bumabalik, minsan hindi)
    baka next week ko na maibalik yung sasakyan ko sa shop, busy weekend, please keep the advices coming mga sir.maraming salamat
    Quote Originally Posted by Boy Bastos View Post
    ito yun sa panel mismo?
    Aug 2009
    Sir baby_scar, one year na pala mahigit nalinis ang aircon ng iyong tsikot kaya ipa check po muna nyo ang inyong evaporator baka barado ng mga dumi kaya nag ice at yan ang dahilan na e trip ang compressor ng thermostat.
    Aug 2009
    Quote Originally Posted by mhelskie View Post
    Binalik ko sa aircon shop yung sportivo and chineck yung freon, okay naman. chineck ng technician yung thermostat, ang sabi nya is nagyeyelo daw - something to do with nawawala wala yung kuryente sa thermostat, so inayos nya. Ala namang naging problema paguwi, pero nung ginamit ko nung gabi to fetch my mom-in-law, nawala yung lamig. Pag andar malamig sya, tapos after 10-15mins, nawala lamig, purohangin na lang. Then on my way to work today, gumana naman sya ng maayos(QC-makati * rush hour).
    sir. we have the same problem. malamig ang ac namin, but kung nasa traffic at idle ang kotse (sometimes kung tumatakbo ang kotse), nawawala ang lamig, i just turn off the aircon. after 5 to 10 minutes. on ko ang AC, ok naman, what is the problem of this? pls help
    pinalitan ko ng bagong aux fan last october 2011. last ac cleaning last april 2010 (change drier) and cleaning condenser etc.
    Jan 2009
    Quote Originally Posted by baby_scar View Post
    Sir, try mo pa-check ung pressure switch ng ac system mo. Kaya nga ung ibang mga mekaniko inaalis nila ung switch kasi paglampas mo lang ng konti sa pressure limit ng switch, ika-cut off na nya ung buong system. Which is good sana kasi it will protect your system like compressor, seal, etc. from over pressure. Pero ang problema lang, kokonti mekaniko lang ang may-alam kung paano mag-diagnose ng ganoong mga problem. Kaya sometimes short-cut na lang ang nangyayari which is the easy way by removing the pressure switch.
    Sana makatulong ito Sir, marami salamat..
    Aug 2009
    Quote Originally Posted by Sure Fire View Post
    sir. maraming salamat for the reply
    if i let the mekaniko remove the pressure switch baka masira ung system ko like compressor etc
    hindi naman aux fan, kasi bago at chaka i get it from a good source. malamig ang aircon, un lang naka idle at traffic wlang lamig lumalabas, konting hangin
    Jan 2011
    Na encounter ko yan din before, thermostat sensor sa evaporator ang naging problem, magtry ka ng ibang sensor sir baka yun din ang problem, maliit lang na wire yun
    Jan 2009
    Usually kasi Sir over pressure occurs pagka kulang ang ventilation ng system like during traffic, idle, etc. Unlike pagka normal ang takbo, marami hangin ang pumapasok. Or in the other hand, baka may barado sa system. Anyway, Sir try mo dalhin ung car mo sa AC shop then ask them to conduct pressure test sa system mo. Alteast malalaman nila dun kung nago-over pressure pa ung system mo. Pagka ganoon nga ung result, medyo matrabaho nga lang ung gagawin kasi baklas lahat then pressure test each part like condenser, evaporator, etc.. Pero kung ok naman ung pressure, try to disconnect the pressure switch, then observe for a meanwhile kung ano magiging result. Don't worry Sir, din naman sya makakasira kasi sandali lang naman. For testing purposes only. Ung iba nga mga Car wala na mga pressure switch pero it runs the system very well.. Pero truly not advisable..
    Sana makatulong ito sayo..
    Aug 2009
    bring it here bro http://www.**************/index.php/...con+Specialist
    ---- pls post the complete link. ayaw mabuksan po. salamat
    same problem sa oto ko bro,pina check ko yung compresor clutch at nakita na malaki na ang space nya kaya binawasan ng washer kaya lang nung binawasan naka dikit na,naghanap pa kami ng mas manipis na washer wala na talaga naka dikit pa rin kaya pinalitan na lang ng clutch,buti na lng may sirang compresor dun sa suking shop ko inilipat yung clutch dun sa compersor ko at ayos tamang tama lang yung gap nung clutch,kaya kinabit na yung compresor sa oto ko,ayun 6 months na ok na ok parin yung aircon ko kahit isabak mo sa bumper to bumper na trapik malamig pa rin,dati sunday car ko na lang yung oto ko nayun kasi walang trapik pag sunday
    Sep 2011
    hi sir, try nyo po p check ang mechanical thermostat at yung a/c relay. pero advice ko lng po kapag ang expansion valve at drier e
    tumagal n ng 3 years dapat ay pinapalitan n po natin, wag napo nating antayin n mag bara ang expansion valve.. or kung every year
    ay nag papalinis naman ng evaporator e dapat pag dating ng 2 years or 24 months ay palitan ang drier para m protektahan ang exp.
    valve at hndi mag bara, advice lng din po wag po nating aalisin or i cut ang pressure switch sa dahilan ito po ang nag sisilbing breaker ng compresor kapag nag hi pressure ang a/c system. salamat po sana makatulong sa inyo po...
    Oct 2005
    probably a sign of a failing compressor.
Nawawala lamig ng aircon
