Results 1 to 10 of 23
Driver/PasaHERO
- 1,310
August 22nd, 2011 05:36 PM #1had a problem w/ my '06 sportivo's aircon last week. May times na nawawala lamig, pero bumabalik din(around 10-20secs walang lamig). I decided to have my aircon cleaned yesterday, ok naman yung linis, walang butas yung condenser(?) na 2(dual aircon), and okay naman karga ng freon. lumakas hangin and malamig sya, pero andun pa din yung intervals na nawawala yung lamig(10-20secs). what could be the problem po?
August 25th, 2011 12:03 AM #2
The problem might be on your Valve and the Dryer, have it checked with your AC technician
August 25th, 2011 12:51 PM #3
bro, try mo itaas ang setting ng thermostat, pag ganon pa rin either pressure switch or magnetic clutch. mura lang parts na nabanggit ko, nag papamahal lang diyan yun service fee, lalo na pag kailangan mag release ng refrigerant...
- Aug 2011
- 674
August 25th, 2011 01:11 PM #4Baka naman ang sira eh yung thermostat switch mismo? Check mo lang baka nawala na sa hinang.
August 25th, 2011 01:14 PM #5
nacheck ba nung technician yung auxfan mo? baka mahina na ikot or malapit na masira... minsan eto rin cause ng pagkawala ng lamig ng aircon
Driver/PasaHERO
- 1,310
August 26th, 2011 10:56 AM #6Binalik ko sa aircon shop yung sportivo and chineck yung freon, okay naman. chineck ng technician yung thermostat, ang sabi nya is nagyeyelo daw - something to do with nawawala wala yung kuryente sa thermostat, so inayos nya. Ala namang naging problema paguwi, pero nung ginamit ko nung gabi to fetch my mom-in-law, nawala yung lamig. Pag andar malamig sya, tapos after 10-15mins, nawala lamig, puro hangin na lang. Then on my way to work today, gumana naman sya ng maayos(QC-makati * rush hour).
Ok naman Aux fan mga sir. Expansion valve? nagiging prob lang ata ito pag totally walang lamig na lumalabas or kulang yung lamig. In my case, pag gumagana yung aircon, malamig tlaga sya, and prob is nawawala yung lamig(minsan bumabalik, minsan hindi)
baka next week ko na maibalik yung sasakyan ko sa shop, busy weekend, please keep the advices coming mga sir.maraming salamat
Driver/PasaHERO
- 1,310
August 26th, 2011 10:56 AM #7.............
- Mar 2004
- 89
November 3rd, 2011 04:25 PM #8its a thermostat issue, kung nag yeyelo....
have you replaced the dryer? baka kasi meron moisture sa line na bumabara sa expansion valve. pag nag yelo yung moisure
- Jun 2011
- 5
November 26th, 2011 10:20 PM #9Bago pa ang Sportivo mo, pero maaring merong bumabara sa condenser. Ipa pressure gauge test mo and AC system sa Service Shop. Normally if walang bara ang condenser nasa 200 psi lang ang reading. Kung tumaas ng 400 psi barado yan at dapat linisin or palitan ng bago. Pag pinalitan ang condensor, SOP na palitan din ang drier.
- Jun 2008
- 1,741
November 26th, 2011 10:54 PM #10Pag nawala ang lamig check mo ang evaporator & return line papunta sa compressor kung may yelo. Kung iyan ay puno ng yelo ang hangin hindi na lalamig kasi barado ang fins. Pag tunaw ng yelo lalamig ulit ang hangin.
1.Possible na sira ang thermostat kaya tuloy-tuloy ang andar ng compressor hanggang magyelo. Bakit may yelo? kasi pag lumamig na ang return line ang expansion valve ay liliit ang bukas in a way na mag throtle ang flow ng refrigerant. Pag mababa na ang pressure sa suction side ng compressor at tuloy pa rin ang andar ang resulta ay mag yelo ang evaporator coil. Ang aircon system ngayon ay umaandar na tulad ng conventional refrigerator (nag yeyelo ang evaporator coil).
2. Kung nakaranas naman ng bukas ang pipings ng aircon mo then maybe may moisture sa loob dahil hindi properly vacuum before recharging the gas. Ang humidity sa loob ng tubo ang maging dahilan ng kalawang na babara sa filter drier at expansion valve. Pag partially clogged ang system eh bababa ang suction line ng compressor. Resulta nito ay katulad sa itaas. Sana makatulong sa iyo para malaman mo kung tama o hindi ang sinasabi ng technician.
Goodluck, peace to all.
