Results 1 to 10 of 10
May 12th, 2008 08:27 AM #1
minsan namamatay ung makina pagnaka on ung aircon..nanginginig din pag naka on... sabi nung erpat ko baka autochuk sensor(di ko sure ung spelling hehe) ung parang nagtataas ng rpm pagnaka on ung ac ang hindi gumagana. i want to have 2nd opinion.... thanks in advance....
- May 2008
- 3
May 12th, 2008 08:30 AM #2
May 12th, 2008 09:33 AM #3
Check the idle speed solenoid maybe its not working, it is supposed to increase the idle to compensate for the extra load the compressor exerts on the engine. RPM drops too low causing the engine to run slightly rich, you can overcome this by increasing the idle or take it to the mechanic to check the solenoid.
Second possible cause is the compressor maybe siezed up, open the hood and turn the A/C on. Now look carefully, see if the clutch is spinning when the A/C kicks on....if it is the compressor could be siezed up.
May 12th, 2008 11:30 AM #5
Have your Idle air controller valve (IACV) checked. baka it needs adjusting lang. Or yung pinaka tosser nya di na gumagana. Pacheck mo na lang kay Mang Mario.
May 14th, 2008 08:16 PM #6
update lang po.. galing ako 2 shops sabi saken servo daw ung kailangan linisin? fuel injected daw kasi... do you think ito ang culprit?
- Apr 2008
- 5
August 14th, 2008 03:03 PM #7mga sir, bago lang din po ako dito, ang ride ko po ay mazda famila 96. yun din ang problem ng auto ko, servo sabi ng mechanic ko. Balak ko dalhin sa rey's marikina sa saturday para linisin, just in case hindi po makuha sa linis, may alam po ba kayong murang bilihan ng mazda servo?
- Nov 2008
- 18
December 10th, 2008 06:51 PM #8sir try nio ung timing sa rator ba un, kasi nun naayos ung makina ko nag iba ung takbo ehg, un pla di maganda pag timing ng rator ewan ko kung tama un ahh, nun adjust na siya ng father ko aun malakas na humatak at tipid sa gasolina, kasi nasusunod agad eh... gets..
December 10th, 2008 09:02 PM #9Have your Idle air controller valve (IACV) checked
December 10th, 2008 09:03 PM #10
double post
Xiaomi E-Car
