Results 1 to 10 of 11
- Mar 2010
- 2
July 8th, 2010 02:32 AM #1mga boss tulong naman sakit na ulo ko sa van ko during trafic nag ooverheat sya
bago palit
timingbelt
aircon cleaning
cylinderhead gasket
fan belt
tapos un condenser q pina lagyan ko na din fan ganon pa din water pump palit na din po pllllllllsssssssss help naman po
- Dec 2006
- 234
- Dec 2008
- 33
July 8th, 2010 07:43 PM #3
- Jul 2010
- 5
July 9th, 2010 10:24 PM #4sir check nyo baka nag fail na yung thermostat ng cooling system mo para ma check mo tanggalin mo yung radiator hose sa ilalim ng rad and sa intake ng water pump and sa kabitan ng hose sa intake ng water pump may 2 bolt doon buksan mo yun and ma aacess mo yung thermostat kapag natanggal mo yan ilagay mo sya sa kumukulong tubig dapat bubukas yung valve kapag nakalubog sya sa kumukulong tubig pag hindi nag open sira na yan and dapat nang palitan kadalasan tinatanggal yan ng iba kasi sabi nila para lang yan sa may mga winter na bansa pero ang real purpose nyan is para madaling mag warm up ang sasakyan reducing incomplete combustion and better fuel consumption
- 25
July 10th, 2010 12:51 PM #5sir paki try un mga sinabi ng ibang members dito.. radiator overhaul and in doing so... remove the thermostat and observe for several days running the van without it. if the problem persist.. therefore its another story and need more comprehensive problem solving.
since tropical country tayo its quite not true na matagal uminit ang engine kapag inalis ang thermostat. if with thermostat your engine will be on running temp at about 2-5mins. without thermostat it will take 5-10mins and will depend on ambient temperature, mas mabilis kung hindi tag-ulan.(sir applicable lang po ito sa non-computer controlled vehicle)
just an example.. un mga passenger jeepneys.. karamihan walang radiator cap at walang thermostat pero bihira din naman un nag-ooverheat sa mga jeepney and yet madalas nakasabak sila sa trapik ng kalye..
July 11th, 2010 11:14 PM #6
Mahirap mapinpoint kung saan ang problema sa overheating...
Yung cooling fan ba ay electric? baka mahina na ito....kailangan na palitan...
radiator mo ba ay luma na at ilang beses na pina overhaul? baka need mo na palitan ng bago....
July 11th, 2010 11:25 PM #7
July 11th, 2010 11:45 PM #8
ilipat yung pwesto ng condenser, dapat d na sya nakaharang sa radiator. saken yung ang naka solve na overheat...
- Mar 2010
- 2
July 13th, 2010 02:42 PM #9
- Jan 2009
- 123
July 13th, 2010 04:46 PM #10Pareho ba ang cooling system ng versa van at mga sedan? Sa oto kasi, at low rpm's as in traffic condition or at matagal na neutral, kapag-umiinit na ang makina to the point na parang lalagpas na sa normal ang water temperature, iikot na ang radiator fan to cool down the engine. In your case, if they are the same, baka hindi na sya umiikot. Nung na-overheat ka, tiningnan mo ba kung umiikot ang radiator fan? Kung hindi sya umiikot, yon ang dahilan.
Puwede siguro gapang ang wire sa space ng rear hatch lifter/struts papunta sa rear bumper, tapos...
