My car is an 06' Chevy Optra 1.6 LS Wagon (Automatic). Last year na notice ko na nawawalan ng lamig yung kotse at humihina yung hangin. So I thought that it might be because it's dirty already. SO, I took it to the shop and the mechanic said that my compressor clutch is not disengaging and that's why its ice-ing up. He said that everything was OK, no leaks and the system is is clean except for clutch problem. The mechanic said that it might be the ECU acting up, he suggested that we add a thermostat and bypass the ECU.
Not being a car nut (and fearing that I'd be buying a new ECU... which will cost me most of my limbs) I asked him to go ahead with the procedure. It worked, the compressor disengages automatically and it doesn't ice up anymore. Problem solved!
Or I thought it was. After a few months, I am now noticing quite a significant power loss everytime the compressor kicks in and a faint "gurgle" when the car is in idle and below 1K rpm. And also sometimes the compressor won't turn on (turing the AC switch on and off after a few minutes solves this issue... pretty annoying)
I've read somewhere that my car automatically cuts off the compressor if it detects that its under load (climbing a hill, overtaking, etc.) and knowing that we've just bypassed the ECU, I might be placing too much stress on my engine because of this. I now want to take it to another AC shop and remove the thermostat, and have it wired the way it was before.
My question now is What could be the cause of the compressor not disengaging? What should I look for and what should I tell the mechanic?
Thanks a lot in advance, and sorry for the eyestrain.
