Originally Posted by
yapoy86
for me, manual thermostat is better than the electronic sensor. electronic thermostat is just a thermal resistor that varies the resistance relative to temperature.. most of these sensor maintains a -5degree temperature (cooling coil temp) that is why your compressor works longer to achieve the -5 degree temp. this will be the cause of ice formation on your cooling coil. your sudden low engine power might be the compressor engaging while driving unlike before that your compressor is always engaged..
