Results 1 to 6 of 6
- Nov 2002
- 194
January 15th, 2003 04:31 PM #1guys, may tumutulo sa drain plug ng radiator ko. tingin ko yun drain plug ang problema...may nabibilhan ba nito or lagyan ko na lang ng teflon (yun white tape-like na nilalagay sa connecting pipes.
thanks.
- Nov 2002
- 13
January 15th, 2003 04:54 PM #2Palagay ko meron..yung Ae92 namin na toyota ganyan din..sampung piso lang dun sa pinakamalapit na auto supply..dinala ko lang yung lumang drain plug..
actually yung parang goma na o-ring nyan plug na yan , parang sa sobrang tagal naluto na sa init..parang flat na sya kaya hindi na maganda yung sealing nya..eh wala namang o-ring kaya buo na palitan mo..sabi ko nga last year..sampung piso lang ang bili ko..
January 16th, 2003 12:59 AM #3
meron sa mga auto supply nyan, dalhin mo sample kasi iba iba size niyan, or better dalhin mo na car mo para ikabit na agad at ma test kung la ng leak.:D:D
January 20th, 2003 07:21 PM #5
y not get the orig one? im sure its not that expensive and it will last longer for sure.
Before the power run both filters are already primed so pre-fill should no longer be an issue, but...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
