Results 11 to 20 of 34
- Oct 2004
- 58
September 17th, 2005 07:04 PM #11tnx guys,ok pa fan and d pa naman nag over heat.n pansin ko pagdating ko na bahay sa gabi check ko wala naman bawas but pag check next morning laki ng bawas sa reserve tank.any idea why?
Tsikot Member Rank 5
- Nov 2003
- 3,849
September 18th, 2005 02:31 PM #12when the engine is hot, the water overflows into the reservoir. when it is cold it gets sucked back into the radiator.
kung nagbabawas ka determine the source of the leak first.
- Oct 2004
- 58
September 18th, 2005 07:35 PM #13tnx migs,problem lapa ako makita source ng leak...even stain ng dried coolant wala.la rin naman water sa exhuast ko.try ko muna mag palit ng radiator cap.tnx
September 20th, 2005 11:02 PM #14
ganyan din problem dati sa 2000 revo diesel ni erpats, mga 1 to 2 cups ang nababawas sa reservior, walang makitang leak pero maputi na loob ng hood, pina-check ko sa Denso pasong tamo at ni-leak test, walang butas na nakita, mga around 400 din yata labor na binayad ko..
then after 10 months (mga april 2005), nag-overheat na, mabilis na maubos yung reservior and pati na rin sa radiator, dinala namin sa denso pasong tamo and meron ng butas yung radiator... general repair or overhaul yata ginawa, less than 2K din inabot, so far hindi na nag-overheat ngayon..
- Oct 2004
- 58
- Oct 2004
- 89
September 24th, 2005 06:59 PM #16same thing is currently happening to my old corolla (GLi '94 model)...nababawasan yung water sa reservoir pero wala namang apparent leak...dala na lang ako ng tubig sa car para sigurado until mahanap ko yung prob...
- Nov 2003
- 3,849
September 25th, 2005 05:32 PM #18
the rate is about 0.5L every 2 weeks. i've been reduced to using water because it's a waste of coolant.
is it easy to replace the coolant hose going to the idle servo? this is a roughly 0.5" diameter hose. is there a special hose for this? there's a slow leak right at my idle servo and i suspect this is where i'm losing coolant.
another thing.. when the engine is running with the radiator cap off, there's very fine bubbling at the radiator cap. yeah, i know, i thought "OMG blowby!!" or something like that.. but there's no water in the oil, and there's no oil in the water. and there's no overheating.
any ideas?
September 25th, 2005 05:52 PM #19
leak lang po sir.i hope na yun lang ang tagas niya.ang hirap kasi mag trace ng tagas.same thing sakin....ilang lingo na ako nag t trace!
Tsikot Member Rank 3
- Dec 2003
- 546
September 25th, 2005 06:53 PM #20orly
my guess its a sign na mamatay na ang water pump mo, antay antay ka na lang, sigurado, bigla na lang iihi engine mo kasi bumigay na ang water pump mo. yung tipong full blown tagas.
nangyayari malamang ngayon may tagas ng kaunti yung water pump mo, kasi vacuum operation din yan, pag may tagas, may hangin sa labas pumapasok sa vacuum ng cooling system, kaya result nun, bula,
now bakit wala nakikita sign ng tubig sa engine mismo, especially dun s a part ng water pump, aside may cover, nag eevaporate yung tagas ng tubig dahil maiinit ang engine.
bakit walang overheat? di pa masyado lala ang leak, may tubig pa ang radiator, mahina ng kaunti ang bomba, at compensated sya ng thermostat,
antay antay ka na lang bro., hehe sigurado titirik ka nyan hehehe pag bigla bumulusok water pump mo bahang sa daan ka.
i don't like hybrids so corolla cross is out for me. but i'd consider a non-hybrid corolla cross...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
